[postgis-users] postgis version consistency issue
rmrodriguez at carto.com
Fri Nov 22 02:26:08 PST 2019
This is a bug in our update process, if you have access to the extension files
($sharedir/extension/postgis--ANY--2.5.2.sql, where sharedir is where postgresql
stores it's share objects, `pg_config --sharedir` should give it to
you) then you can
edit the file, and look for a block like this to delete it:
DO language 'plpgsql'
BEGIN
IF _postgis_scripts_pgsql_version()::integer >= 96 THEN
-- mark ST_Union agg as parallel safe if it is not already
UPDATE pg_proc SET proparallel = 's'
WHERE oid = 'st_union(geometry)'::regprocedure AND proparallel = 'u';
END IF;
END;
Deleting these 10 lines should allow you to update without issues,
you'll need to run
the `ALTER EXTENSION postgis UPDATE` after the fact.
I'll create an issue to handle this better in following releases so it
doesn't stop updates.
On Fri, Nov 22, 2019 at 11:00 AM <olivier.lobry at umontpellier.fr> wrote:
> Hi
> It looks like I have installation issues with postgis.
> I recently upgrade from pg 9.3 / postgis 2.2.x to pg 11 / postgis 2.5.2
> But I now have some issues with some Postgis functions. For instance :
> SELECT
> st_collect(t.geom) AS geom
> FROM
> a_table t
> rises :
> ERROR: could not access file "$libdir/postgis-2.4": No such file or directory
> SQL state: 58P01
> It seems it looks for version 2.4, while 2.5.2 is installed :
> $ dpkg -l | grep postgis
> ii postgis 2.5.2+dfsg-1~exp1.pgdg90+1 amd64 Geographic objects support for PostgreSQL
> ii postgis-doc 2.5.2+dfsg-1~exp1.pgdg90+1 all Geographic objects support for PostgreSQL -- documentation
> ii postgresql-11-postgis-2.5 2.5.2+dfsg-1~exp1.pgdg90+1 amd64 Geographic objects support for PostgreSQL 11
> ii postgresql-11-postgis-2.5-scripts 2.5.2+dfsg-1~exp1.pgdg90+1 all Geographic objects support for PostgreSQL 11 -- SQL scripts
> $ psql -d OSU -c "SELECT PostGIS_full_version();"
> postgis_full_version
> POSTGIS="2.5.2 r17328" GEOS="3.5.1-CAPI-1.9.1 r4246" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.1.2, released 2016/10/24" LIBXML="2.9.4" LIBJSON="0.12.1" TOPOLOGY RASTER
> And what is strange is that \dx gives version 2.1.3…
> whereas postgis_topology is ok
> why ??
> $ psql -d OSU -c "\dx"
> List of installed extensions
> Name | Version | Schema | Description
> postgis | 2.1.3 | public | PostGIS geometry, geography, and raster spatial types and functions
> postgis_topology | 2.5.2 | topology | PostGIS topology spatial types and functions
> If I try to upgrade I obtain this error :
> $ psql -d OSU -c "ALTER EXTENSION postgis UPDATE;"
> ERROR: function "st_union(geometry)" does not exist
> LINE 2: WHERE oid = 'st_union(geometry)'::regprocedure AND proparal...
> QUERY: UPDATE pg_proc SET proparallel = 's'
> CONTEXT: PL/pgSQL function inline_code_block line 5 at SQL statement
> Anyone know how I can fix this version consistency issues and have a clean installation ??
> Thank you for your help
> Regards
> Olivier
> Olivier Lobry
> Ingénieur de Recherche
> Chargé du Système d'Information
> OSU OREME
> UMS 3282 CNRS - UMS 223 IRD
> www.oreme.org / data.oreme.org
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Raúl Marín Rodríguez
carto.com
