[postgis-users] ST_Subdivide creates nodes outside original polygon
Eduardo Ramos
duda.ramos at gmail.com
Tue Nov 26 08:26:07 PST 2019
Hello all.
I'm exploring the function ST_Subdivide(with type geometry) and noticed
that the nodes that this function creates to divide the original polygon
are missing the polygon edges by ~6cm.
Here is an example:
[image: image.png]
This is originating some issues when using the ST_Intersects because the
new polygons generated by ST_Subdivide are intersecting polygons that were
not being intersected before.
I guess this must be a matter of numeric precision but I we can't control
the precision or the tolerance in either of the two functions (ST_Subdivide
and ST_Intersects).
Is there a way to configure the precision of ST_Subdivide or to play with
the ST_Intersects tolerance?
Any ideas or suggestions?
Thanks,
Eduardo
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191126/87430f7f/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191126/87430f7f/attachment.png>
