[postgis-users] ST_Subdivide creates nodes outside original polygon
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Wed Nov 27 00:28:41 PST 2019
Can you share a testcase?
Are you running PostGIS 2.5+ so ST_Subdivide will try to reuse the original
node?
On Tue, Nov 26, 2019 at 7:24 PM Eduardo Ramos <duda.ramos at gmail.com> wrote:
> Hello all.
> I'm exploring the function ST_Subdivide(with type geometry) and noticed
> that the nodes that this function creates to divide the original polygon
> are missing the polygon edges by ~6cm.
> Here is an example:
> [image: image.png]
> This is originating some issues when using the ST_Intersects because the
> new polygons generated by ST_Subdivide are intersecting polygons that were
> not being intersected before.
> I guess this must be a matter of numeric precision but I we can't control
> the precision or the tolerance in either of the two functions (ST_Subdivide
> and ST_Intersects).
> Is there a way to configure the precision of ST_Subdivide or to play with
> the ST_Intersects tolerance?
> Any ideas or suggestions?
> Thanks,
> Eduardo
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191127/154d8938/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191127/154d8938/attachment.png>
