[postgis-users] ST_Subdivide creates nodes outside original polygon
Eduardo Ramos
duda.ramos at gmail.com
Fri Nov 29 06:59:12 PST 2019
Hi, thanks for your responses.
I managed to improve the results by installing PostGIS 2.5.3 (many thanks
@Darafei). It solved almost all the cases.
But to completely remove the "error", I've created a 'tolerance' by
calculating the intersection area and checking that it was greater than a
0.00000001.
It solved the problem and the performance impact is little to none. It
hurted a little bit to do this, though...
Eduardo
On Wed, 27 Nov 2019 at 08:29, Darafei "Komяpa" Praliaskouski <me at komzpa.net>
wrote:
> Hi,
> Can you share a testcase?
> Are you running PostGIS 2.5+ so ST_Subdivide will try to reuse the
> original node?
> On Tue, Nov 26, 2019 at 7:24 PM Eduardo Ramos <duda.ramos at gmail.com>
> wrote:
>> Hello all.
>> I'm exploring the function ST_Subdivide(with type geometry) and noticed
>> that the nodes that this function creates to divide the original polygon
>> are missing the polygon edges by ~6cm.
>> Here is an example:
>> [image: image.png]
>> This is originating some issues when using the ST_Intersects because the
>> new polygons generated by ST_Subdivide are intersecting polygons that were
>> not being intersected before.
>> I guess this must be a matter of numeric precision but I we can't control
>> the precision or the tolerance in either of the two functions (ST_Subdivide
>> and ST_Intersects).
>> Is there a way to configure the precision of ST_Subdivide or to play with
>> the ST_Intersects tolerance?
>> Any ideas or suggestions?
>> Thanks,
>> Eduardo
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191129/5e9dfca7/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191129/5e9dfca7/attachment.png>
