[postgis-users] ST_Union(ST_Buffer(...)) hangs for large polygons on RHEL7/CentOS7 / PG 9.5
Jason Greenlaw - NOAA Affiliate
jason.greenlaw at noaa.gov
Fri Oct 11 12:51:58 PDT 2019
For those interested, the GEOS performance regression was filed at
https://trac.osgeo.org/geos/ticket/997
A functioning workaround is to call ST_SnapToGrid on the buffered geometry
before the union operation, e.g. ST_Union(ST_SnapToGrid(ST_Buffer(...),
0.0001))
Jason
On Wed, Oct 9, 2019 at 2:54 PM Jason Greenlaw - NOAA Affiliate <
jason.greenlaw at noaa.gov> wrote:
> I did a bit more testing and determined that the 3.6.1 -> 3.6.2 regression
> does not actually appear to be the cause. Instead, performance issues for
> my use-case seem to have been introduced between 3.6.x -> 3.7.0.
> With PostGIS 2.3.7 / GEOS 3.6.1, query took ~85 seconds on my machine:
> POSTGIS="2.3.7 r16523" PGSQL="95" GEOS="3.6.1-CAPI-1.10.1 r0" PROJ="Rel.
> 4.9.3, 15 August 2016" GDAL="GDAL 1.11.4, released 2016/01/25"
> LIBXML="2.9.1" LIBJSON="0.11" RASTER
> EXPLAIN ANALYZE SELECT ST_Union(ST_Buffer(wkb_geometry,
> 100.0))::geometry(Geometry,
> 3857),category,vteccode,prod_type,validtime,starttime,endtime FROM
> public.nws_haz_hang_201910 GROUP BY
> category,vteccode,prod_type,validtime,starttime,endtime;
> QUERY PLAN
> HashAggregate (cost=10.30..10.45 rows=10 width=706) (actual
> time=35922.055..85310.959 rows=5 loops=1)
> Group Key: category, vteccode, prod_type, validtime, starttime, endtime
> -> Seq Scan on nws_haz_hang_201910 (cost=0.00..10.10 rows=10
> width=706) (actual time=0.014..0.053 rows=21 loops=1)
> Planning time: 0.460 ms
> Execution time: 85314.516 ms
> (5 rows)
> I got similar timings with GEOS 3.6.2 (90 sec), 3.6.3 (89 sec) and 3.6.4
> (100 sec), but when testing with 3.7.0, the command took 70 minutes to
> finish.
> I've kept the PostGIS version at 2.3 for this round of testing because 2.5
> was not working with GEOS 3.6.0 (error about missing
> function GEOSFrechetDistanceDensify).
> I also tested 3.8.0rc3 (which contains the recent performance fix
> <https://github.com/libgeos/geos/commit/6bac4f45e94f8e18409803b17eb306dd94fa065a#diff-ee28c8845c72c5f8c7307c430276b944>
> ported from JTS) with PostGIS 2.5.3, but that too showed severe performance
> issues for my use-case, with the command finally finishing after 2 hours 27
> minutes.
> If anyone has additional insight please let me know. I will likely do a
> few more tests and follow up with a GEOS bug report.
> Thanks,
> Jason
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191011/14db2393/attachment.html>
