[postgis-users] Fw: PGSQL 10.9 vs PGSQL 9.6 SQL query dirrent result when using GIS PGspehere indexes
Ghiurea, Isabella
Isabella.Ghiurea at nrc-cnrc.gc.ca
Mon Oct 21 12:38:55 PDT 2019
Hi List
we are facing some issues when running same SQL in different PG version using
GIS spatial index aka PGsphere pos index in PG SQL 10.9 vs 9.5.16 .
In PG 9,5.16 we are seeing the correct/expecting number of rows returned BUT in in PG 10.9 we are seeing 0 rows been returned
Here is in PG9.5.16
and pgsphere-1.1.aaf2d56-000.x86_64
EXPLAIN ANALYZE SELECT count(*), min(degrees(long(pos))), max(degrees(long(pos))), min(degrees(long(pos))), max(degrees(lat(pos)))FROM xxx.DR1 WHERE pos <@ spoly '{(189.1d,30.9d),(192.1d,30.9d),(192.1d,33.9d),(189.1d,33.9d)}';
QUERY PLAN
Aggregate (cost=1358997.31..1358997.32 rows=1 width=16) (actual time=52963.730..52963.730 rows=1 loops=1)
-> Bitmap Heap Scan on dr1 (cost=16178.35..1345855.58 rows=404361 width=16) (actual time=411.320..51291.281 rows=1255823 loops=1)
Recheck Cond: (pos <@ '{(3.30041761552128 , 0.539306738866248),(3.35277749308111 , 0.539306738866248),(3.35277749308111 , 0.591666616426078),(3.30041761552128 , 0.591666616426078)}.
.'::spoly)
Rows Removed by Index Recheck: 150145
Heap Blocks: exact=38113
-> Bitmap Index Scan on i_dr1_pos (cost=0.00..16077.26 rows=404361 width=0) (actual time=402.564..402.564 rows=1405968 loops=1)
Index Cond: (pos <@ '{(3.30041761552128 , 0.539306738866248),(3.35277749308111 , 0.539306738866248),(3.35277749308111 , 0.591666616426078),(3.30041761552128 , 0.5916666164260.
.78)}'::spoly)
Planning time: 3.096 ms
Execution time: 52964.699 ms
(9 rows)
and PG10.9: with
pgsphere10-1.1.1-4.rhel7.x86_64
[local]:5432 postgres at youcatdb-#FROMXXX.DR1 WHERE pos <@ spoly '{(189.1d,30.9d),(192.1d,30.9d),(192.1d,33.9d),(189.1d,33.9d)}';
QUERY PLAN
Aggregate (cost=732312.22..732312.23 rows=1 width=40) (actual time=0.023..0.023 rows=1 loops=1)
-> Bitmap Heap Scan on dr1 (cost=9377.77..719172.89 rows=404287 width=16) (actual time=0.016..0.016 rows=0 loops=1)
.'::spoly)
-> Bitmap Index Scan on i_dr1_pos (cost=0.00..9276.70 rows=404287 width=0) (actual time=0.012..0.012 rows=0 loops=1)
.78)}'::spoly)
Planning time: 0.243 ms
Execution time: 0.177 ms
(7 rows)
Any idea what can cause this ?
Thank you
Isabella
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20191021/0dbcfa73/attachment.html>
