[postgis-users] Upgrade issues
James Sewell
james.sewell at jirotech.com
Tue Sep 3 15:42:37 PDT 2019
I will do some more testing today to make sure it’s not PG or POSTGIS
version dependent - but yes to both at this stage.
On Wed, 4 Sep 2019 at 12:42 am, Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> > On Sep 3, 2019, at 6:20 AM, Regina Obe <lr at pcorp.us> wrote:
> > Oh didn’t think of that one. That ‘s a bummer. PostGIS has supported
> other long/lat spatial ref sys since PostGIS 2.2.
> > I think if you use anything other than 4326 though it has to look in the
> spatial_ref_sys table for some things. I’m guessing it’s checking to make
> sure 4283 is a valid entry in spatial_ref_sys.
> > I’m not sure why it doesn’t need to check for geometry or maybe we just
> never bother since geometry if you can’t transform it is not a huge deal
> and things like 0 srid aren’t in the spatial_ref_sys anyway.
> > Paul – any thoughts on how to fix this one?
> None. Is it easily replicable? Does any non-standard geography srid
> trigger it?
> P
> > Thanks,
> > Regina
> > From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
> Behalf Of James Sewell
> > Sent: Monday, September 2, 2019 8:32 PM
> > To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> > Subject: Re: [postgis-users] Upgrade issues
> > Sadly that's not the case - the issue is with the actual Geometry column.
> > ERROR: relation "public.spatial_ref_sys" does not exist
> > LINE 21: location_pt public.geography(Point,4283),
> > I'm curious how this ever worked?
> > James
> > On Tue, 3 Sep 2019 at 09:35, Regina Obe <lr at pcorp.us> wrote:
> >> I recall Raúl mentioning he triggered this. I think he had something
> like a table constraint on ST_Buffer(geog.. ) or some other function that
> internally relies on spatial_ref_sys.
> >> The issue is that since spatial_ref_sys is a table, pg_upgrade doesn’t
> populate before it populates other tables. pg_upgrade first makes the
> structure of all the tables and pg_upgrade doesn’t know it needs to
> populate the data in spatial_ref_sys before the other tables as it does a
> create extensions in non-standard way when migrating the data to maintain
> same exact functions/data etc as it had before.
> >> I thought we fixed this issue like in 2.5.3, but I I can’t find the bug
> fix notice in the notices, so maybe not. I also can’t remember what ticket
> it was but I think it is ticketed.
> >> What you could do is drop the offending constraint before you
> pg_upgrade, and then create it after the upgrade is done.
> >> Sent: Sunday, September 1, 2019 10:59 PM
> >> To: postgis-users at lists.osgeo.org
> >> Subject: [postgis-users] Upgrade issues
> >> Hi all,
> >> I'm upgrading from 9.6 -> 11. Both versions have PostGIS 2.5.1.
> >> The upgrade starts then I see this in the logs:
> >> pg_restore: [archiver (db)] could not execute query: ERROR: relation
> >> LINE 39: "location_pt" "public"."geography"(Point,4283),
> >> Above this I can see:
> >> pg_restore: creating EXTENSION "postgis"
> >> This is created fine - it just doesn't make the PostGIS tables in any
> schema?
> >> Has anyone seen anything like this before?
> >> Cheers,
> >> James Sewell,
> >> The contents of this email are confidential and may be subject to legal
> or professional privilege and copyright. No representation is made that
> this email is free of viruses or other defects. If you have received this
> communication in error, you may not copy or distribute any part of it or
> otherwise disclose its contents to anyone. Please advise the sender of your
> incorrect receipt of this correspondence.
> >> _______________________________________________
> >> postgis-users mailing list
> >> https://lists.osgeo.org/mailman/listinfo/postgis-users
James Sewell,
Chief Architect
Suite 112, Jones Bay Wharf, 26-32 Pirrama Road, Pyrmont NSW 2009
P (+61) 2 8099 9000 W www.jirotech.com F (+61) 2 8099 9099
The contents of this email are confidential and may be subject to legal or
professional privilege and copyright. No representation is made that this
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190904/c0cea735/attachment.html>
