[postgis-users] Upgrade issues
James Sewell
james.sewell at jirotech.com
Tue Sep 3 19:25:56 PDT 2019
> > Paul – any thoughts on how to fix this one?
>> None. Is it easily replicable? Does any non-standard geography srid
>> trigger it?
Making some progress now.
It looks like pg_upgrade from any (tested 9.6, 10, -> 11) version of
Postgres will fail if any version of PostGIS (tested 2.5.1, 3.0) is
installed and a table with a Geography, non 4326 SRID column exists.
The failure can take one of two forms:
a) When the table is created spatial_ref_sys doesn't exist
b) When the table is created spatial_ref_sys exists but is empty (data
isn't added till after the schema import using pg_upgrade)
I can't answer is how this has not been hit before???
The contents of this email are confidential and may be subject to legal or
professional privilege and copyright. No representation is made that this
email is free of viruses or other defects. If you have received this
communication in error, you may not copy or distribute any part of it or
otherwise disclose its contents to anyone. Please advise the sender of your
incorrect receipt of this correspondence.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20190904/b68db1b3/attachment.html>
