[postgis-users] Can we treat a large block of psql codes as a string and execute the string?
Giuseppe Broccolo g.broccolo.7 at gmail.com
Tue Apr 21 15:08:18 PDT 2020
Hi Shao,
Maybe you are looking about how to pass SQL statements via a shell
here-document:
psql [options] <<EOF
SELECT *
FROM foo1
WHERE col='val';
SELECT * FROM foo2;
EOF
Eventual bash variable within the here-document can be interpolated.
To avoid that just quote the first instance of EOF
psql [options] <<'EOF'
SELECT *
FROM foo1
WHERE col='val';
SELECT * FROM foo2;
EOF
Il giorno mar 21 apr 2020 alle ore 21:16 Shaozhong SHI <
shishaozhong at gmail.com> ha scritto:
> It is quite appealing to wrap up a large block of psql codes as a string
> and execute the string.
> And, how to deal with quotes within quotes.
> I tried short text strings.  It worked well, but it does not seem to work
> with very long strings in different lines.
> Can anyone shed light on this?
> Regards,
> Shao
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200421/421256f7/attachment.html>
