[postgis-users] Can we treat a large block of psql codes as a string and execute the string?
Shaozhong SHI
shishaozhong at gmail.com
Tue Apr 21 23:34:39 PDT 2020
Hi, Giuseppe,
See the following code to see what I am trying to do.
DO $$
DECLARE
wccdate TEXT;
output TEXT := 'public.topographic_line_buckinghamshire_milton_keynes_line';
psqlstring TEXT;
BEGIN
execute format('ALTER TABLE %s ADD style_description varchar(50)', output);
execute format('ALTER TABLE %s ADD style_code int2', output);
psqlstring := 'UPDATE' || output || "SET style_description = CASE WHEN
descriptiveterm ~* 'Polygon Closing Link' THEN 'Polygon Closing Line' ELSE
'Unclassified' END";
psqlstring := psqlstring || "'," || " " || output || ")'";
execute psqlstring;
END $$;
The other day when I composed a very long string to do something else, it
worked.
Now, I am trying to make update statement and then execute the string.
But, I keep get error message saying the string gets truncated.
Regards,
Shao
On Tue, 21 Apr 2020 at 23:09, Giuseppe Broccolo <g.broccolo.7 at gmail.com>
wrote:
> Hi Shao,
> Maybe you are looking about how to pass SQL statements via a shell
> here-document:
> psql [options] <<EOF
> SELECT *
> FROM foo1
> WHERE col='val';
> SELECT * FROM foo2;
> EOF
> Eventual bash variable within the here-document can be interpolated. To avoid that just quote the first instance of EOF
> psql [options] <<'EOF'
> SELECT *
> FROM foo1
> WHERE col='val';
> SELECT * FROM foo2;
> EOF
> Il giorno mar 21 apr 2020 alle ore 21:16 Shaozhong SHI <
> shishaozhong at gmail.com> ha scritto:
>> It is quite appealing to wrap up a large block of psql codes as a string
>> and execute the string.
>> And, how to deal with quotes within quotes.
>> I tried short text strings. It worked well, but it does not seem to work
>> with very long strings in different lines.
>> Can anyone shed light on this?
>> Regards,
>> Shao
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200422/5c19e1b6/attachment.html>
