[postgis-users] Can we treat a large block of psql codes as a string and execute the string?
Shaozhong SHI
shishaozhong at gmail.com
Wed Apr 22 00:33:54 PDT 2020
Hi, Giuseppe,
I am following these examples.
https://stackoverflow.com/questions/12780275/dynamic-sql-query-in-postgres
But, it appears that it does not allow long text strings.
I wonder how to go about.
Regards,
Shao
On Wed, 22 Apr 2020 at 07:47, Shaozhong SHI <shishaozhong at gmail.com> wrote:
> Hi, Giuseppe,
> The following is the error message.
> NOTICE: identifier "SET style_description = CASE WHEN descriptiveterm ~*
> 'Polygon Closing Link' THEN 'Polygon Closing Line' ELSE 'Unclassified' END"
> will be truncated to "SET style_description = CASE WHEN descriptiveterm ~*
> 'Polygon C" NOTICE: identifier "SET style_description = CASE WHEN
> descriptiveterm ~* 'Polygon Closing Link' THEN 'Polygon Closing Line' ELSE
> 'Unclassified' END" will be truncated to "SET style_description = CASE WHEN
> descriptiveterm ~* 'Polygon C" LINE 11: psqlstring := 'UPDATE' || output ||
> "SET style_description =... ^ ERROR: syntax error at or near "exec" LINE
> 13: exec psqlstring; ^ SQL state: 42601 Character: 501
> Regards,
> Shao
> On Wed, 22 Apr 2020 at 07:34, Shaozhong SHI <shishaozhong at gmail.com>
> wrote:
>> Hi, Giuseppe,
>> See the following code to see what I am trying to do.
>> DO $$
>> DECLARE
>> wccdate TEXT;
>> output TEXT :=
>> 'public.topographic_line_buckinghamshire_milton_keynes_line';
>> psqlstring TEXT;
>> BEGIN
>> execute format('ALTER TABLE %s ADD style_description varchar(50)',
>> output);
>> execute format('ALTER TABLE %s ADD style_code int2', output);
>> psqlstring := 'UPDATE' || output || "SET style_description = CASE WHEN
>> 'Unclassified' END";
>> psqlstring := psqlstring || "'," || " " || output || ")'";
>> execute psqlstring;
>> END $$;
>> The other day when I composed a very long string to do something else, it
>> worked.
>> Now, I am trying to make update statement and then execute the string.
>> But, I keep get error message saying the string gets truncated.
>> Regards,
>> Shao
>> On Tue, 21 Apr 2020 at 23:09, Giuseppe Broccolo <g.broccolo.7 at gmail.com>
>> wrote:
>>> Hi Shao,
>>> Maybe you are looking about how to pass SQL statements via a shell
>>> here-document:
>>> psql [options] <<EOF
>>> SELECT *
>>> FROM foo1
>>> WHERE col='val';
>>> SELECT * FROM foo2;
>>> EOF
>>> Eventual bash variable within the here-document can be interpolated. To avoid that just quote the first instance of EOF
>>> psql [options] <<'EOF'
>>> SELECT *
>>> FROM foo1
>>> WHERE col='val';
>>> SELECT * FROM foo2;
>>> EOF
>>> Il giorno mar 21 apr 2020 alle ore 21:16 Shaozhong SHI <
>>> shishaozhong at gmail.com> ha scritto:
>>>> It is quite appealing to wrap up a large block of psql codes as a
>>>> string and execute the string.
>>>> And, how to deal with quotes within quotes.
>>>> I tried short text strings. It worked well, but it does not seem to
>>>> work with very long strings in different lines.
>>>> Can anyone shed light on this?
>>>> Regards,
>>>> Shao
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200422/da0c6a74/attachment.html>
