[postgis-users] Postgis spatial join display error
Tsering W. Shawa
shawatw at princeton.edu
Tue Apr 28 09:32:18 PDT 2020
I am new to PostGIS and trying to learn how everything works. I am using Introduction to PostGIS site data to test different GIS function including spatial join. The spatial join SQL statement seems to work [SELECT * FROM nyc_neighborhoods AS n JOIN nyc_subway_stations AS s ON ST_Contains(n.geom, s.geom); ] but when I try to add the result to the QGIS I get an error message saying "there was an error creating the SQL layer". When I tried the simpler the SQL function by selecting only row with a particular name [SELECT * FROM nyc_neighborhoods WHERE name = 'Soho';]. The SQL statement worked as well as I was able to add the SQL layer on a map. I am using QGIS's DB Manager to write SQL statements.
I was wondering what I am missing here.
Any suggestions or help will be appreciated. FYI. I have installed PostgreSQL 12 with PostGIS 3.
Many thanks,
-Tsering
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200428/bdd84125/attachment.html>
