[postgis-users] Postgis spatial join display error
Regina Obe
lr at pcorp.us
Tue Apr 28 09:45:35 PDT 2020
Try doing
SELECT s.*, n.name AS neighborhood FROM nyc_neighborhoods AS n JOIN
nyc_subway_stations AS s ON ST_Contains(n.geom, s.geom);
When you do *, it picks up all columns from both tables and I don't think
QGIS likes duplicated columns
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Tsering W. Shawa
Sent: Tuesday, April 28, 2020 12:32 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Postgis spatial join display error
I am new to PostGIS and trying to learn how everything works. I am using
Introduction to PostGIS site data to test different GIS function including
spatial join. The spatial join SQL statement seems to work [SELECT * FROM
nyc_neighborhoods AS n JOIN nyc_subway_stations AS s ON ST_Contains(n.geom,
s.geom); ] but when I try to add the result to the QGIS I get an error
message saying "there was an error creating the SQL layer". When I tried the
simpler the SQL function by selecting only row with a particular name
[SELECT * FROM nyc_neighborhoods WHERE name = 'Soho';]. The SQL statement
worked as well as I was able to add the SQL layer on a map. I am using
QGIS's DB Manager to write SQL statements.
I was wondering what I am missing here.
Any suggestions or help will be appreciated. FYI. I have installed
PostgreSQL 12 with PostGIS 3.
Many thanks,
-Tsering
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200428/a0cede3a/attachment.html>
