[postgis-users] Find LineString segment index containing closest point?
Martin Davis
mtnclimb at gmail.com
Wed Aug 5 08:59:53 PDT 2020
Returning a record with all information is a nice extension. Might choose
a different function name, though.
And agreed, it makes more sense to make the index 0-based, to match the
ST_AddPoint function. The point index origin in PostGIS functions seems to
a be bit inconsistent - or is it only ST_PointN which is different?
On Wed, Aug 5, 2020 at 8:46 AM Bruce Rindahl <bruce.rindahl at gmail.com>
wrote:
> My two cents:
> Since you are computing the distance, why not return it? Also make the
> index zero based like most of the other st_ functions.
> CREATE OR REPLACE FUNCTION ST_LineLocateN( line geometry, pt geometry )
> RETURNS table(index integer, dist double precision)
> AS $$
> SELECT i - 1, dist FROM (
> SELECT i, ST_Distance(
> ST_MakeLine( ST_PointN( line, s.i ), ST_PointN( line, s.i+1 ) ),
> pt) AS dist
> FROM generate_series(1, ST_NumPoints( line )-1) AS s(i)
> ORDER BY dist
> ) AS t LIMIT 1;
> LANGUAGE sql STABLE STRICT;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200805/d0838259/attachment.html>
