[postgis-users] Find LineString segment index containing closest point?
Bruce Rindahl
bruce.rindahl at gmail.com
Wed Aug 5 08:46:24 PDT 2020
My two cents:
Since you are computing the distance, why not return it? Also make the
index zero based like most of the other st_ functions.
CREATE OR REPLACE FUNCTION ST_LineLocateN( line geometry, pt geometry )
RETURNS table(index integer, dist double precision)
AS $$
SELECT i - 1, dist FROM (
SELECT i, ST_Distance(
ST_MakeLine( ST_PointN( line, s.i ), ST_PointN( line, s.i+1 ) ),
pt) AS dist
FROM generate_series(1, ST_NumPoints( line )-1) AS s(i)
ORDER BY dist
) AS t LIMIT 1;
LANGUAGE sql STABLE STRICT;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200805/7e1773aa/attachment.html>
