[postgis-users] Storing geometries in variables
Shaozhong SHI
shishaozhong at gmail.com
Fri Aug 21 09:18:51 PDT 2020
Hi, Ruven Brooks,
This is a good point.
I was testing in a Do statement. I created a geometry variable. It seems
that it stored a geometry object. However, a very long code appeared. It
does not seem that the geometry object was not actually stored.
Regards,
Shao
On Fri, 21 Aug 2020 at 15:32, <ruvenml at beamerbrooks.com> wrote:
> SQL itself has no variables. What programming language are you using and
> how does it call SQL? PosgGIS supports WKT format so pretty much any
> programming language which can store strings can store geometry.
> Ruven Brooks
> On 8/21/2020 7:54 AM, Shaozhong SHI wrote:
> Has anyone got experience in storing geometries in variables, so that
> these can be used in a program?
> Regards,
> Shao
> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200821/b1aeda3f/attachment.html>
