[postgis-users] Storing geometries in variables
ruvenml at beamerbrooks.com
Fri Aug 21 10:51:40 PDT 2020
The DO statement is not in standard SQL; it is a PostgreSQL extension
used to implement procedural languages like PL/SQL. Are you writing
PL/SQL code? If so, it would be useful to have an explanation of what
you are trying to compute, particularly if the computations are
geometric ones.
Ruven Brooks
On 8/21/2020 11:18 AM, Shaozhong SHI wrote:
> Hi, Ruven Brooks,
> This is a good point.
> I was testing in a Do statement. I created a geometry variable. It
> seems that it stored a geometry object. However, a very long code
> appeared. It does not seem that the geometry object was not actually
> stored.
> Regards,
> Shao
> On Fri, 21 Aug 2020 at 15:32, <ruvenml at beamerbrooks.com
> <mailto:ruvenml at beamerbrooks.com>> wrote:
> SQL itself has no variables. What programming language are you
> using and how does it call SQL? PosgGIS supports WKT format so
> pretty much any programming language which can store strings can
> store geometry.
> Ruven Brooks
> On 8/21/2020 7:54 AM, Shaozhong SHI wrote:
>> Has anyone got experience in storing geometries in variables, so
>> that these can be used in a program?
>> Regards,
>> Shao
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/postgis-users <https://lists.osgeo.org/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200821/53b530be/attachment.html>
