[postgis-users] Storing geometries in variables
Shaozhong SHI
shishaozhong at gmail.com
Fri Aug 21 11:33:25 PDT 2020
Hi, Ruven Brooks,
I am trying to explore its potential and versatility.
Can standard SQL work like a program?
As I understand, DO statement is similar to a function.
What I am interested in is to fully understand its capabilities and working
like a program.
Working like to powerful program would allow data manipulation.
Have you tried writing DO statement with Python?
Regards,
Shao
On Fri, 21 Aug 2020 at 18:52, <ruvenml at beamerbrooks.com> wrote:
> The DO statement is not in standard SQL; it is a PostgreSQL extension used
> to implement procedural languages like PL/SQL. Are you writing PL/SQL
> code? If so, it would be useful to have an explanation of what you are
> trying to compute, particularly if the computations are geometric ones.
> Ruven Brooks
> On 8/21/2020 11:18 AM, Shaozhong SHI wrote:
> Hi, Ruven Brooks,
> This is a good point.
> I was testing in a Do statement. I created a geometry variable. It seems
> that it stored a geometry object. However, a very long code appeared. It
> does not seem that the geometry object was not actually stored.
> Regards,
> Shao
> On Fri, 21 Aug 2020 at 15:32, <ruvenml at beamerbrooks.com> wrote:
>> SQL itself has no variables. What programming language are you using
>> and how does it call SQL? PosgGIS supports WKT format so pretty much any
>> programming language which can store strings can store geometry.
>> Ruven Brooks
>> On 8/21/2020 7:54 AM, Shaozhong SHI wrote:
>> Has anyone got experience in storing geometries in variables, so that
>> these can be used in a program?
>> Regards,
>> Shao
>> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200821/45bf32fe/attachment.html>
