[postgis-users] Storing geometries in variables
Shaozhong SHI
shishaozhong at gmail.com
Fri Aug 21 13:00:18 PDT 2020
Hi, Steve,
I have already read that. I am reading this one now.
https://www.postgresql.org/docs/9.0/plpython.html
I find it interesting and intriguing. If a Do statement or a function can
also be written in Python, would that imply that highly complex processing
can be done this way?
Would this add on processing power of Python onto PostgreSQL/PostGIS?
I wonder who has experience on this.
Regards,
Shao
On Fri, 21 Aug 2020 at 19:46, Stephen Woodbridge <
stephenwoodbridge37 at gmail.com> wrote:
> Hi Shao,
> You need to read up on plpgsql stored procedures. This allows you to
> write functions that you can call from SQL. Sql is not a programming
> language like Python/Perl/Basic/etc, It is a query language for working
> with relational databases and operates on sets of records.
> PostgreSQL stored procedures allow you to write and apply functions to
> records or columns via the SQL language. This is what PostGIS does. If
> you have a table of polygons, you can apply an area calculation to the
> polygons in the table of some subset of them like:
> select *, st_area(geom) as area from my_table;
> select *, st_area(geom) as area from my_table where gid=1234;
> If you want to write some complex analysis, write a stored procedure and
> then apply it like above. plpgsql has flow control, variables, etc like
> many other languages.
> -Steve
> On 8/21/2020 2:33 PM, Shaozhong SHI wrote:
> > Hi, Ruven Brooks,
> > I am trying to explore its potential and versatility.
> > Can standard SQL work like a program?
> > As I understand, DO statement is similar to a function.
> > What I am interested in is to fully understand its capabilities and
> > working like a program.
> > Working like to powerful program would allow data manipulation.
> > Have you tried writing DO statement with Python?
> > Regards,
> > Shao
> > On Fri, 21 Aug 2020 at 18:52, <ruvenml at beamerbrooks.com
> > <mailto:ruvenml at beamerbrooks.com>> wrote:
> > The DO statement is not in standard SQL; it is a PostgreSQL
> > extension used to implement procedural languages like PL/SQL. Are
> > you writing PL/SQL code? If so, it would be useful to have an
> > explanation of what you are trying to compute, particularly if the
> > computations are geometric ones.
> > Ruven Brooks
> > On 8/21/2020 11:18 AM, Shaozhong SHI wrote:
> >> Hi, Ruven Brooks,
> >> This is a good point.
> >> I was testing in a Do statement. I created a geometry variable.
> >> It seems that it stored a geometry object. However, a very long
> >> code appeared. It does not seem that the geometry object was not
> >> actually stored.
> >> Regards,
> >> Shao
> >> On Fri, 21 Aug 2020 at 15:32, <ruvenml at beamerbrooks.com
> >> SQL itself has no variables. What programming language are
> >> you using and how does it call SQL? PosgGIS supports WKT
> >> format so pretty much any programming language which can
> >> store strings can store geometry.
> >> Ruven Brooks
> >> On 8/21/2020 7:54 AM, Shaozhong SHI wrote:
> >>> Has anyone got experience in storing geometries in
> >>> variables, so that these can be used in a program?
> >>> Regards,
> >>> Shao
> >>> _______________________________________________
> >>> postgis-users mailing list
> >>> postgis-users at lists.osgeo.org <mailto:
> postgis-users at lists.osgeo.org>
> >>> https://lists.osgeo.org/mailman/listinfo/postgis-users
> >> <mailto:postgis-users at lists.osgeo.org>
> > postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200821/71b29177/attachment.html>
