[postgis-users] Storing geometries in variables
Shaozhong SHI shishaozhong at gmail.com
Sat Aug 22 04:08:06 PDT 2020
Hi, Ruven Brooks,
Thanks a lot.
I know Python well, and have been doing a lot of coding lately.
Your advice does help me to understand the matter clearly.
Thanks again.
Regards,
Shao
On Fri, 21 Aug 2020 at 23:11, <ruvenml at beamerbrooks.com> wrote:
> You're far better off going the other way.   It's really easy to call
> PostgreSQL/PostGIS from Python and there are lots of tutorials and
> examples.  The advantage of doing it this way is you can also use Python
> for user interface interaction and graphical data display.
> An alternative to consider if maps are particularly of interest is to
> write most of your code in Javascript.   PostgresSQL can create JSON which
> can be fed directly to Leaflet or Google Maps to display as maps.
> It turns out that SQL is Turing Complete (without pl/SQL).  This means
> that any computation you can write in Python or any other programming
> language, you can write in SQL.  In other words, SQL is already as powerful
> as Python.  What this claim doesn't say is how large and long the program
> will be and how fast it will run.  Unfortunately, that depends on the
> specific computation and the answer could go either way.
> The typical usage of pl/SQL and pl/Python are like the one Stephen
> Woodbridge gave, writing a function like st_area which takes just a single
> column of a single row as input and returns a floating point value.  The
> postgreSQL query optimizer does not optimize pl/SQL functions so the
> programmer must be extremely careful to write these efficiently.
> Ruven Brooks
> On 8/21/2020 3:00 PM, Shaozhong SHI wrote:
> Hi, Steve,
> I have already read that.  I am reading this one now.
> https://www.postgresql.org/docs/9.0/plpython.html
> I find it interesting and intriguing.  If a Do statement or a function can
> also be written in Python, would that imply that highly complex processing
> can be done this way?
> Would this add on processing power of Python onto PostgreSQL/PostGIS?
> I wonder who has experience on this.
> Regards,
> Shao
> On Fri, 21 Aug 2020 at 19:46, Stephen Woodbridge <
> stephenwoodbridge37 at gmail.com> wrote:
>> Hi Shao,
>> You need to read up on plpgsql stored procedures. This allows you to
>> write functions that you can call from SQL. Sql is not a programming
>> language like Python/Perl/Basic/etc, It is a query language for working
>> with relational databases and operates on sets of records.
>> PostgreSQL stored procedures allow you to write and apply functions to
>> records or columns via the SQL language. This is what PostGIS does. If
>> you have a table of polygons, you can apply an area calculation to the
>> polygons in the table of some subset of them like:
>> select *, st_area(geom) as area from my_table;
>> select *, st_area(geom) as area from my_table where gid=1234;
>> If you want to write some complex analysis, write a stored procedure and
>> then apply it like above. plpgsql has flow control, variables, etc like
>> many other languages.
>> -Steve
>> On 8/21/2020 2:33 PM, Shaozhong SHI wrote:
>> > Hi, Ruven Brooks,
>> > I am trying to explore its potential and versatility.
>> > Can standard SQL work like a program?
>> > As I understand, DO statement is similar to a function.
>> > What I am interested in is to fully understand its capabilities and
>> > working like a program.
>> > Working like to powerful program would allow data manipulation.
>> > Have you tried writing DO statement with Python?
>> > Regards,
>> > Shao
>> > On Fri, 21 Aug 2020 at 18:52, <ruvenml at beamerbrooks.com
>> > <mailto:ruvenml at beamerbrooks.com>> wrote:
>> >     The DO statement is not in standard SQL; it is a PostgreSQL
>> >     extension used to implement procedural languages like PL/SQL. Are
>> >     you writing PL/SQL code?   If so, it would be useful to have an
>> >     explanation of what you are trying to compute, particularly if the
>> >     computations are geometric ones.
>> >     Ruven Brooks
>> >     On 8/21/2020 11:18 AM, Shaozhong SHI wrote:
>> >>     Hi, Ruven Brooks,
>> >>     This is a good point.
>> >>     I was testing in a Do statement.  I created a geometry variable.
>> >>     It seems that it stored a geometry object.  However, a very long
>> >>     code appeared.  It does not seem that the geometry object was not
>> >>     actually stored.
>> >>     Regards,
>> >>     Shao
>> >>     On Fri, 21 Aug 2020 at 15:32, <ruvenml at beamerbrooks.com
>> >>         SQL itself has no variables.   What programming language are
>> >>         you using and how does it call SQL? PosgGIS supports WKT
>> >>         format so pretty much any programming language which can
>> >>         store strings can store geometry.
>> >>         Ruven Brooks
>> >>         On 8/21/2020 7:54 AM, Shaozhong SHI wrote:
>> >>>         Has anyone got experience in storing geometries in
>> >>>         variables, so that these can be used in a program?
>> >>>         Regards,
>> >>>         Shao
>> >>>         _______________________________________________
>> >>>         postgis-users mailing list
>> >>>         postgis-users at lists.osgeo.org  <mailto:
>> postgis-users at lists.osgeo.org>
>> >>>         https://lists.osgeo.org/mailman/listinfo/postgis-users
>> >>         <mailto:postgis-users at lists.osgeo.org>
>> >     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org
> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200822/54571040/attachment.html>
