[postgis-users] Postgres Crash with st_orientation on single dataset
Mike Treglia mtreglia at gmail.com
Tue Dec 8 18:48:01 PST 2020
Hi All,
I was just trying to troubleshoot something with a dataset, and when
running st_orientation on it, postgres crashes. Potentially related to this
old bug report? https://trac.osgeo.org/postgis/ticket/3651
I'm working on Windows 10, 64 bit, with Postgres 13.0, with postgres and
postgis installed through EnterpriseDB.  PostGIS and related info is here:
POSTGIS="3.0.2 3.0.2" [EXTENSION] PGSQL="130" GEOS="3.8.1-CAPI-1.13.3"
SFCGAL="1.3.8" PROJ="6.3.2" GDAL="GDAL 3.0.4, released 2020/01/28 GDAL_DATA
not found" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.4.3
(Internal)" TOPOLOGY RASTER
Below is the log, which includes the sql statement (I renamed the dataset
for some data anonymity in case that matters).  I'm not sure if it's
something about a specific feature, or the dataset itself that's causing an
issue.
Mostly just wanted to share in case it's not a known issue, and if there's
anything else I can provide that would be useful, happy to do so (though
the dataset is not shareable, unfortunately).
Best,
Mike
2020-12-08 21:32:16.998 EST [7136] LOG:  server process (PID 24536) was
terminated by exception 0xC00000FD
2020-12-08 21:32:16.998 EST [7136] DETAIL:  Failed process was running:
select st_orientation((st_dump(geom_2263)).geom) as orient, count(*) from
nac_data.test_data
group by orient
2020-12-08 21:32:16.998 EST [7136] HINT:  See C include file "ntstatus.h"
for a description of the hexadecimal value.
2020-12-08 21:32:17.000 EST [7136] LOG:  terminating any other active
server processes
2020-12-08 21:32:17.022 EST [12112] WARNING:  terminating connection
because of crash of another server process
2020-12-08 21:32:17.022 EST [12112] DETAIL:  The postmaster has commanded
this server process to roll back the current transaction and exit, because
another server process exited abnormally and possibly corrupted shared
memory.
2020-12-08 21:32:17.022 EST [12112] HINT:  In a moment you should be able
to reconnect to the database and repeat your command.
2020-12-08 21:32:17.022 EST [12008] WARNING:  terminating connection
2020-12-08 21:32:17.022 EST [12008] DETAIL:  The postmaster has commanded
memory.
2020-12-08 21:32:17.022 EST [12008] HINT:  In a moment you should be able
2020-12-08 21:32:17.034 EST [22696] WARNING:  terminating connection
2020-12-08 21:32:17.034 EST [22696] DETAIL:  The postmaster has commanded
memory.
2020-12-08 21:32:17.034 EST [22696] HINT:  In a moment you should be able
2020-12-08 21:32:17.033 EST [8476] WARNING:  terminating connection because
2020-12-08 21:32:17.033 EST [8476] DETAIL:  The postmaster has commanded
memory.
2020-12-08 21:32:17.033 EST [8476] HINT:  In a moment you should be able to
2020-12-08 21:32:17.033 EST [8476] CONTEXT:  while scanning block 102119 of
relation "results_scratch.nac_ecml2"
2020-12-08 21:32:17.036 EST [25352] WARNING:  terminating connection
2020-12-08 21:32:17.036 EST [25352] DETAIL:  The postmaster has commanded
memory.
2020-12-08 21:32:17.036 EST [25352] HINT:  In a moment you should be able
2020-12-08 21:32:17.060 EST [7136] LOG:  all server processes terminated;
reinitializing
2020-12-08 21:32:17.141 EST [23844] LOG:  database system was interrupted;
last known up at 2020-12-08 21:27:47 EST
2020-12-08 21:32:17.195 EST [22960] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:17.339 EST [25660] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:17.406 EST [26996] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:17.533 EST [3096] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:17.621 EST [26160] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:17.717 EST [23828] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:17.747 EST [23904] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:17.780 EST [24808] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:17.846 EST [26036] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:17.906 EST [1116] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:17.976 EST [22556] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:18.045 EST [28448] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:18.107 EST [25316] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:18.174 EST [22180] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:18.238 EST [14504] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:18.870 EST [13132] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:19.802 EST [24976] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:20.826 EST [28144] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:21.857 EST [18416] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:21.959 EST [23844] LOG:  database system was not properly
shut down; automatic recovery in progress
2020-12-08 21:32:21.971 EST [23844] LOG:  redo starts at 7/E540C568
2020-12-08 21:32:22.834 EST [22308] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:23.892 EST [22736] FATAL:  the database system is in
recovery mode
2020-12-08 21:32:24.872 EST [27520] FATAL:  the database system is in
recovery mode
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201208/425a28e5/attachment.html>
