[postgis-users] Postgres Crash with st_orientation on single dataset
Regina Obe
lr at pcorp.us
Tue Dec 8 19:32:33 PST 2020
Yah it is still an issue. I’ve just reopened that ticket. It was on me to provide a debug trace with SFCGAL symbols on windows so SFCGAL group could trace it. Seems the issue has only happened on windows so far so might be windows specific.
I confirmed the test Paul provided on that ticket
Still crashes on windows –
PostgreSQL 13.1, compiled by Visual C++ build 1914, 64-bit
POSTGIS="3.1.0dev 3.1.0alpha2-157-gdfeaaac70" [EXTENSION] PGSQL="130" GEOS="3.9.0beta2-CAPI-0.15.1" SFCGAL="1.3.8" PROJ="6.3.2" GDAL="GDAL 3.2.0, released 2020/10/26" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Mike Treglia
Sent: Tuesday, December 8, 2020 9:48 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: [postgis-users] Postgres Crash with st_orientation on single dataset
Hi All,
I was just trying to troubleshoot something with a dataset, and when running st_orientation on it, postgres crashes. Potentially related to this old bug report? https://trac.osgeo.org/postgis/ticket/3651
I'm working on Windows 10, 64 bit, with Postgres 13.0, with postgres and postgis installed through EnterpriseDB. PostGIS and related info is here:
POSTGIS="3.0.2 3.0.2" [EXTENSION] PGSQL="130" GEOS="3.8.1-CAPI-1.13.3" SFCGAL="1.3.8" PROJ="6.3.2" GDAL="GDAL 3.0.4, released 2020/01/28 GDAL_DATA not found" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.4.3 (Internal)" TOPOLOGY RASTER
Below is the log, which includes the sql statement (I renamed the dataset for some data anonymity in case that matters). I'm not sure if it's something about a specific feature, or the dataset itself that's causing an issue.
Mostly just wanted to share in case it's not a known issue, and if there's anything else I can provide that would be useful, happy to do so (though the dataset is not shareable, unfortunately).
Best,
Mike
2020-12-08 21:32:16.998 EST [7136] LOG: server process (PID 24536) was terminated by exception 0xC00000FD
2020-12-08 21:32:16.998 EST [7136] DETAIL: Failed process was running: select st_orientation((st_dump(geom_2263)).geom) as orient, count(*) from nac_data.test_data
group by orient
2020-12-08 21:32:16.998 EST [7136] HINT: See C include file "ntstatus.h" for a description of the hexadecimal value.
2020-12-08 21:32:17.000 EST [7136] LOG: terminating any other active server processes
2020-12-08 21:32:17.022 EST [12112] WARNING: terminating connection because of crash of another server process
2020-12-08 21:32:17.022 EST [12112] DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
2020-12-08 21:32:17.022 EST [12112] HINT: In a moment you should be able to reconnect to the database and repeat your command.
2020-12-08 21:32:17.022 EST [12008] WARNING: terminating connection because of crash of another server process
2020-12-08 21:32:17.022 EST [12008] DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
2020-12-08 21:32:17.022 EST [12008] HINT: In a moment you should be able to reconnect to the database and repeat your command.
2020-12-08 21:32:17.034 EST [22696] WARNING: terminating connection because of crash of another server process
2020-12-08 21:32:17.034 EST [22696] DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
2020-12-08 21:32:17.034 EST [22696] HINT: In a moment you should be able to reconnect to the database and repeat your command.
2020-12-08 21:32:17.033 EST [8476] WARNING: terminating connection because of crash of another server process
2020-12-08 21:32:17.033 EST [8476] DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
2020-12-08 21:32:17.033 EST [8476] HINT: In a moment you should be able to reconnect to the database and repeat your command.
2020-12-08 21:32:17.033 EST [8476] CONTEXT: while scanning block 102119 of relation "results_scratch.nac_ecml2"
2020-12-08 21:32:17.036 EST [25352] WARNING: terminating connection because of crash of another server process
2020-12-08 21:32:17.036 EST [25352] DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
2020-12-08 21:32:17.036 EST [25352] HINT: In a moment you should be able to reconnect to the database and repeat your command.
2020-12-08 21:32:17.060 EST [7136] LOG: all server processes terminated; reinitializing
2020-12-08 21:32:17.141 EST [23844] LOG: database system was interrupted; last known up at 2020-12-08 21:27:47 EST
2020-12-08 21:32:17.195 EST [22960] FATAL: the database system is in recovery mode
2020-12-08 21:32:17.339 EST [25660] FATAL: the database system is in recovery mode
2020-12-08 21:32:17.406 EST [26996] FATAL: the database system is in recovery mode
2020-12-08 21:32:17.533 EST [3096] FATAL: the database system is in recovery mode
2020-12-08 21:32:17.621 EST [26160] FATAL: the database system is in recovery mode
2020-12-08 21:32:17.717 EST [23828] FATAL: the database system is in recovery mode
2020-12-08 21:32:17.747 EST [23904] FATAL: the database system is in recovery mode
2020-12-08 21:32:17.780 EST [24808] FATAL: the database system is in recovery mode
2020-12-08 21:32:17.846 EST [26036] FATAL: the database system is in recovery mode
2020-12-08 21:32:17.906 EST [1116] FATAL: the database system is in recovery mode
2020-12-08 21:32:17.976 EST [22556] FATAL: the database system is in recovery mode
2020-12-08 21:32:18.045 EST [28448] FATAL: the database system is in recovery mode
2020-12-08 21:32:18.107 EST [25316] FATAL: the database system is in recovery mode
2020-12-08 21:32:18.174 EST [22180] FATAL: the database system is in recovery mode
2020-12-08 21:32:18.238 EST [14504] FATAL: the database system is in recovery mode
2020-12-08 21:32:18.870 EST [13132] FATAL: the database system is in recovery mode
2020-12-08 21:32:19.802 EST [24976] FATAL: the database system is in recovery mode
2020-12-08 21:32:20.826 EST [28144] FATAL: the database system is in recovery mode
2020-12-08 21:32:21.857 EST [18416] FATAL: the database system is in recovery mode
2020-12-08 21:32:21.959 EST [23844] LOG: database system was not properly shut down; automatic recovery in progress
2020-12-08 21:32:21.971 EST [23844] LOG: redo starts at 7/E540C568
2020-12-08 21:32:22.834 EST [22308] FATAL: the database system is in recovery mode
2020-12-08 21:32:23.892 EST [22736] FATAL: the database system is in recovery mode
2020-12-08 21:32:24.872 EST [27520] FATAL: the database system is in recovery mode
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201208/bf4541d2/attachment.html>
