[postgis-users] ERROR: invalid regular expression: parentheses () not balanced
Paul Ramsey pramsey at cleverelephant.ca
Thu Dec 17 15:22:17 PST 2020
A LIKE query just gets re-written into an equivalent regex in the backend. There is no free lunch.
This can be fast, if you build an index using text_pattern_ops like
 CREATE INDEX ON footable (foo text_pattern_ops);
 SELECT * FROM footable WHERE foo LIKE 'bar%';
This will never be fast
 SELECT * FROM tootable WHERE foo LIKE '%bar';
(Well, unless you're clever and index and search it in reverse.)
If you want something to find particular words in a larger collection of words quickly, research full text search.
https://www.postgresql.org/docs/current/textsearch.html
If you want to look for parts of words and partial matches, research pg_tgrm.
https://www.postgresql.org/docs/current/pgtrgm.html
P
> On Dec 17, 2020, at 3:13 PM, Thiemo Kellner <thiemo at gelassene-pferde.biz> wrote:
> In the case that the task is to select all records from mytable where the full_address contains the string pao_text, the like clause is probably much more efficient:
> select * from mytable where full_address like '%pao_text%';
> Performance might not be an issue here but it is never bad to have an eye on efficiency in my opinion.
> Cheers
> Thiemo
> Quoting Bo Victor Thomsen <bo.victor.thomsen at gmail.com>:
>> select * from mytable where full_address ~* 'pao_text';
>> You've forgotten the string delimiters
>> Med venlig hilsen / Kind regards
>> Bo Victor Thomsen
>> Den 17-12-2020 kl. 11:53 skrev Shaozhong SHI:
>>> select * from mytable where full_address ~* pao_text;
> S/MIME Public Key: https://oc.gelassene-pferde.biz/index.php/s/eJuAUFONag6ofnH
> Signal (Safer than WhatsApp): +49 1578 7723737
> Threema (Safer than WhatsApp): A76MKH3J
> Handys: +41 78 947 36 21 | +49 1578 772 37 37
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
