[postgis-users] ST_ClusterDBSCAN for "geography" data type?
Marco Boeringa
marco at boeringa.demon.nl
Mon Dec 21 03:25:17 PST 2020
Hi Giuseppe,
Thanks for confirming what I already suspected, and that "geography" is
not supported.
Maybe, as a first step to implementing this, just assuming the globe is
a perfect sphere instead of spheroid, would help in easing implementing
something like this for "geography", and provide significant performance
benefits as well. Since 'ST_ClusterDBSCAN' is already a non
deterministic process, the error of assuming the globe is a sphere is
not particularily relevant I think, but would allow you to run the
clustering process against a global data set.
Marco
Op 21-12-2020 om 12:15 schreef Giuseppe Broccolo:
> Hi Marco,
> Il giorno dom 20 dic 2020 alle ore 10:03 Marco Boeringa
> <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl>> ha scritto:
> Hi,
> Reading through the PostGIS documentation, I noticed the
> "ST_ClusterDBSCAN" function takes a distance as one of the inputs.
> Now
> the docs suggest the current algorithm only takes in "geometry" type
> data. Is that true? Based on the distance input variable, it would
> seem
> logical to have a "geography" variant as well, even if that is a
> considerably slower variant considering the more complex distance
> calculation.
> Yes, ST_ClusterDBSCAN takes just the geometry type in input. This is
> because most of the algorithm
> is implemented using utilities already existing in GEOS for planar
> geometries.
> Adding the support for the geography type would mean to re-implement
> the algorithm specifically for
> spherical objects, as you mentioned.
> Regards,
> Giuseppe.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201221/0cafd56e/attachment.html>
