[postgis-users] ST_ClusterDBSCAN for "geography" data type?
Marco Boeringa
marco at boeringa.demon.nl
Mon Dec 21 06:06:13 PST 2020
Hi Darafei,
Thanks for the suggestion.
I must admit I have a bit of difficulty visualizing what this exactly
does, and had to look up that EPSG:4978 projection you mention, but do I
understand it right that the solution you suggest should work for global
data sets, and isn't influenced or limited by the usual projection
distortions?
I also understand this is not something I could easily run myself,
because this is experimental changes in underlying PostGIS code? Or is
there a set of PostGIS commands I need to run in specific order to get
such result, e.g. is it really as simple as maybe:
"ST_ClusterDBSCAN(ST_Force3D(ST_Transform(<GEOMETRY_COLUMN>,4978)))" ??
Marco
Op 21-12-2020 om 12:24 schreef Darafei "Komяpa" Praliaskouski:
> Hi,
> My last exercise in KMeans showed that it's enough to add support for
> 3D distances instead of 2D distances in the code and transform your
> geometry into EPSG:4978 (after Force3D). That will cluster in a 3D XYZ
> coordinate system using straight lines in 3D, which is usually good
> enough.
> On Mon, Dec 21, 2020 at 2:15 PM Giuseppe Broccolo
> <g.broccolo.7 at gmail.com <mailto:g.broccolo.7 at gmail.com>> wrote:
> Hi Marco,
> Il giorno dom 20 dic 2020 alle ore 10:03 Marco Boeringa
> <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl>> ha scritto:
> Hi,
> Reading through the PostGIS documentation, I noticed the
> "ST_ClusterDBSCAN" function takes a distance as one of the
> inputs. Now
> the docs suggest the current algorithm only takes in
> "geometry" type
> data. Is that true? Based on the distance input variable, it
> would seem
> logical to have a "geography" variant as well, even if that is a
> considerably slower variant considering the more complex distance
> calculation.
> Yes, ST_ClusterDBSCAN takes just the geometry type in input. This
> is because most of the algorithm
> is implemented using utilities already existing in GEOS for planar
> geometries.
> Adding the support for the geography type would mean to
> re-implement the algorithm specifically for
> spherical objects, as you mentioned.
> Regards,
> Giuseppe.
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> <https://lists.osgeo.org/mailman/listinfo/postgis-users>
> OSM BY Team - http://openstreetmap.by/ <http://openstreetmap.by/>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201221/a77e19d1/attachment.html>
