[postgis-users] magnetic bearing to true bearing
James Klassen klassen.js at gmail.com
Fri Feb 7 06:32:48 PST 2020
This will calculate the declamation.  It would take some C coding to
integrate it with PostgreSQL.
https://www.ngdc.noaa.gov/geomag/WMM/soft.shtml
On Fri, Feb 7, 2020, 08:14 <paul.malm at lfv.se> wrote:
> Hi, list!
> I’m writing a program reading a file and creating graphical objects.
> I have a starting point (lat/lon WGS 84), a length (m) and a magnetic
> bearing (degrees).
> I would like to automatically convert the magnetic bearing to a true
> bearing when they occurs in the file I’m reading.
> Is there a converter in PostGis that can be used, or is there another way
> my program can get the declamation?
> Kind regard,
> Paul
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200207/be592fff/attachment.html>
