[postgis-users] PostGIS 2.5.4 is Released
Paul Ramsey
pramsey at cleverelephant.ca
Fri Feb 28 10:50:59 PST 2020
https://postgis.net/2020/02/28/postgis-2.5.4/
Just a bug fix release, but lots of bugs.
https://download.osgeo.org/postgis/source/postgis-2.5.4.tar.gz
Enjoy!
* Bug fixes *
- #4480, Geography Distance inconsistent with Intersects (Paul Ramsey)
- #4481, Improve libprotobuf detection for old systems (Paul Ramsey)
- #4475, Avoid reading into empty ptarray (Paul Ramsey)
- #4492, Fix ST_Simplify ignoring the value of the 3rd parameter (Raúl Marín)
- #4494, Fix ST_Simplify output having an outdated bbox (Raúl Marín)
- #4493, Fix ST_RemoveRepeatedPoints output having an outdated bbox (Raúl Marín)
- #4495, Fix ST_SnapToGrid output having an outdated bbox (Raúl Marín)
- #4496, Make ST_Simplify(TRIANGLE) collapse if requested (Raúl Marín)
- #4506, Remove tolerance in point-in-ring tests (Paul Ramsey)
- #4338, Fix Census block level data (tabblock table) loading (Regina Obe)
- #4519, Fix getSRIDbySRS crash (Raúl Marín)
- #4517, Documentation error ST_EndPoint (Samuel Spurling)
- #4530, Avoid bogus AddRasterConstraint in upgrade tests (Sandro Santilli)
- #4534, Fix leak in lwcurvepoly_from_wkb_state (Raúl Marín)
- #4536, Fix leak in lwcollection_from_wkb_state (Raúl Marín)
- #4537, Fix leak in WKT collection parser (Raúl Marín)
- #4547, Fix AddRasterConstraints handling of empty tables (Sandro Santilli)
- #4549, Fix schema qualification of internal types (Raúl Marín)
- #4546, Fix PLPGSQL functions missing the schema qualification (Raúl Marín)
- #4588, Fix update when st_union(geometry) doesn't exist (Raúl Marín)
- #4599, ST_AddPoint: Accept -1 as a valid position (Raúl Marín)
- #4605, Fix postgis_upgrade.pl with PostgreSQL 12 (Matti Linnanvuori)
- #4621, Prevent stack overflow when parsing WKB (Raúl Marín)
- #4626, Support pkg-config for libxml2 (Bas Couwenberg)
- #4646, Fix gserialized_cmp incorrect comparison (dkvash)
