[postgis-users] How does PostGIS / PostgreSQL distribute parallel work to cores for GIS type data?
Marco Boeringa
marco at boeringa.demon.nl
Fri Feb 28 14:06:33 PST 2020
Hi all,
With some of the recent discussions related to PostgreSQL 12.x / PostGIS
3.x query execution performance and parallel query processing, I have
been wondering how PostGIS / PostgreSQL actually distribute parallel
work for GIS type data? Is there any form of load balancing to different
cores?
GIS type data fundamentally differs from "traditional" data with simple
text or numeric fields in one crucial aspect: the size distribution of
geometries is vastly greater than any difference in size of other basic
field types in a database.
E.g. polygon geometries may vary from very simple 3 vertex triangle
shapes, to vast country boundary polygons having over 1M vertexes. This
has a *huge* impact on processing time per record as well. With
geometries over 100k vertices, you quickly end up with processing times
- per record! - that may extend in the minutes or even hours and in bad
cases a day for a single geometry.
This means that simply distributing parallel work by distributing e.g.
100M records over 10M chunks for 10 parallel workers, each worker simply
getting the next set of available records to process until all have been
assigned to a core / parallel worker, can end up very bad in terms of
load balancing.
Let's assume for example that the table indeed has multiple records with
geometries over 1M vertexes in size, and that all of them happen to be
in the first 10M chunk of records, whereas the rest of the records has
vastly smaller geometries. This could mean a single parallel worker
ending up needing to process the bulk of the data in terms of sheer
vertex count, and it might as well be processing for days on it! Whereas
the other parallel workers, maybe needing to process only 10% percent of
all vertex complexity in the table, finish in a few hours.
I actually personally developed a Python multi-threaded generalization
option that circumvents such issues: it uses the geometry's vertex count
as returned by the PostGIS 'ST_NPoints' function to distribute records
evenly across all parallel threads. By sorting the records by vertex
count, and than interleaving all records from the highest to the lowest
vertex count to all parallel threads, all threads end up processing
approximately the same number of vertexes. This leads to pretty nice
load balancing, with all threads finishing in approximately the same
timespan, and all cores of my server maxed out.
I realize PostGIS is dependent on PostgreSQL for parallel query
execution, and that something like described above may not be directly
feasible in a PostgreSQL / PostGIS default installation. Nonetheless I
have wondered how the current mechanism for parallel query with GIS data
is implemented, and if there is any load balancing based on geometry
complexity?
Marco Boeringa
