[postgis-users] Errors in loading table with geom which was produced with pg-dump
Shaozhong SHI
shishaozhong at gmail.com
Fri Jan 24 22:10:13 PST 2020
I do not know why.
What I am looking for is a robust and efficient way to do the following.
Make a copy of a table from a database.
Load it into another database.
It needs to work with tables with from.
On Friday, 24 January 2020, Regina Obe <lr at pcorp.us> wrote:
> Shao,
> You are still not providing enough information.
> We need the exact command you were using on pg_dump. For example only if
> you are doing a plain text dump with pg_dump, can you use psql to load it.
> A binary or tar dump needs to be loaded with pg_restore. This piece of
> information is missing in your below explanation and could be why you are
> getting invalid commands.
> Same goes for psql
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Shaozhong SHI
> *Sent:* Friday, January 24, 2020 6:44 AM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] Errors in loading table with geom which
> Hi, Raul Marin Rodriguez,
> We are using PostgreSQL version 10.10 and postgis version 2.4.8 .
> The command used for dump the data is pg_dump.exe.
> The command used for import data is psql.exe.
> The error message is full of invalid commands.
> Regards,
> Shao
> On Thu, 23 Jan 2020 at 17:28, <rmrodriguez at carto.com> wrote:
> On Thu, Jan 23, 2020 at 6:23 PM Shaozhong SHI <shishaozhong at gmail.com>
> wrote:
> > I used pg_dump to dump a table with from. Then, I used psql to load it
> to another database, but it showed numerous errors.
> > Why does that happen?
> Hi,
> You are not providing any information to debug the issue. The
> following information would help:
> - Postgresql and Postgis version of both the source and target database.
> - The command used to dump the data.
> - The command used to import the data.
> - The error messages.
> Raúl Marín Rodríguez
> carto.com
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200125/e9812636/attachment.html>
