[postgis-users] dump and restore
Regina Obe
lr at pcorp.us
Thu Jun 18 10:18:21 PDT 2020
You are probably installing into a newer version of PostGIS is my guess and
PostGIS 3+ now has postgis_raster as a separate extension.
Your restore only has CREATE EXTENSION postgis; so would be missing the
postgis_raster bit.
If you need raster support, you should do
create newdb
In you newdb database run
CREATE EXTENSION postgis_raster;
Then follow with your restore
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Crawford Jr., Stephen Rand
Sent: Thursday, June 18, 2020 11:57 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] dump and restore
All,
I have a postGIS database that I am moving to a new machine. I tried these
forms of dump and restore, which have worked on other databases:
pg_dump -Fc db > db.dump
createdb newdb
pg_restore -v -d newdb db.dump
But for this database restore hangs on the first table, which is full of
rasters, as are most of the tables in this database. Are there any other
flags or techniques that I should be using?
Thanks,
Steve
Stephen Crawford
Center For Environmental Informatics
The Pennsylvania State University
src176 at psu.edu <mailto:src176 at psu.edu>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200618/d38b5cd9/attachment.html>
