[postgis-users] Running raster2pgsql on AWS
    Alexander Gataric
    gataric at usa.net
    Fri Jun 19 10:47:45 PDT 2020
I want to run command line Postgres tools directly on AWS. What is the best approach for this? I know how to access AWS Postgres via psql on my machine and connecting to the host.
On Jun 18, 2020, 12:18 PM, at 12:18 PM, Regina Obe <lr at pcorp.us> wrote:
>You are probably installing into a newer version of PostGIS is my guess
>and
>PostGIS 3+ now has postgis_raster as a separate extension.
>Your restore only has CREATE EXTENSION postgis;  so would be missing
>the
>postgis_raster bit.
>If you need raster support, you should do
>create newdb
>In you newdb database run
>CREATE EXTENSION postgis_raster;
>Then follow with your restore
>From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
>Behalf
>Of Crawford Jr., Stephen Rand
>Sent: Thursday, June 18, 2020 11:57 AM
>To: postgis-users at lists.osgeo.org
>Subject: [postgis-users] dump and restore
>All,
>I have a postGIS database that I am moving to a new machine.  I tried
>these
>forms of dump and restore, which have worked on other databases:
>pg_dump -Fc db > db.dump
>createdb newdb
>pg_restore -v -d newdb db.dump
>But for this database restore hangs on the first table, which is full
>of
>rasters, as are most of the tables in this database.  Are there any
>other
>flags or techniques that I should be using?
>Thanks,
>Steve
>Stephen Crawford
>Center For Environmental Informatics
>The Pennsylvania State University
>src176 at psu.edu <mailto:src176 at psu.edu>
>_______________________________________________
>postgis-users mailing list
>https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200619/1a3a396a/attachment.html>
