[postgis-users] How does PostGIS / PostgreSQL distribute parallel work to cores for GIS type data?
Marco Boeringa marco at boeringa.demon.nl
Sun Mar 1 03:36:07 PST 2020
Hi Darafei,
Sorry, but I do not have the intimate knowledge of the intricacies of
PostgreSQL / PostGIS that you have, so my post was more of the layman's
level regarding the database itself. My main expertise is more in the
field of GIS.
Anyway, regarding your post, I think this already answers some of my
questions and thoughts.
As I see it from a GIS perspective, there is one other main difference
with "traditional" OLTP databases for e.g. a commercial bank: many GIS
type - analytical - operations hit *all* records / tuples of a table as
default. This is a really uncommon scenario for a "traditional" database
system. E.g., if you want to calculate the area, perimeter, buffer or
either types of geometry attributes or derivatives, you usually - but
not always - do it for all records in an entire table.
This means a sequential scan of the entire table, with all records being
updated and all geometries read (yes, I know this is not recommended,
and dropping and re-creating may be more efficient, but it is a really
common operation from a GIS perspective, both QGIS and ArcGIS have these
"Field Calculator" type tools to do that). This is why it might make
sense to distribute records based on geometry complexity, to level out
any differences in vertex load in tables having an unpredictable and
uneven distribution of records with large geometries.
Quote:
"Parallel Seq Scan divides table in equal size and gives each part to
its own worker. It is expected that any nuance in parallel scan is
offset by multiple queries running at the same time."
While I can see that logic being utterly reasonable for a "traditional"
OLTP database, is that also true for GIS type data with the vast size
distribution of geometries? Although it is hard to give figures here,
because I do not have a fully equivalent non-multi threaded processing
flow, I do see significant benefits from distributing records based on
vertex complexity. This is OpenStreetMap data, and some of the records
being processed (also due to some other intermediate processing I do),
are well over 100k vertexes, and need processing in the minutes per
record. I certainly do not see issues with "multiple queries running at
the same time" as inhibiting the multi-threaded process flow. With 8-16
connections opened (one for each processing thread) in my multi-threaded
implementation, PostgreSQL / PostGIS seem to be handling the heavy
processing fine (on SSD of course).
Marco
Op 1-3-2020 om 11:15 schreef Darafei "Komяpa" Praliaskouski:
> Hi,
> Can you please be more specific with the question?
> Parallelism is tuple level. All load balancing is provided by Postgres
> - different Parallel Scan types have different ordering properties and
> different tuple passing graph.
> Parallel index scan pushes out each tuple to next free worker,
> essentially balancing it out. Parallel Seq Scan divides table in equal
> size and gives each part to its own worker.
> It is expected that any nuance in parallel scan is offset by multiple
> Also, proper index usage beats parallel scan most of the time.
> Thanks.
> On Sat, Feb 29, 2020 at 1:06 AM Marco Boeringa <marco at boeringa.demon.nl> wrote:
>> Hi all,
>> With some of the recent discussions related to PostgreSQL 12.x / PostGIS
>> 3.x query execution performance and parallel query processing, I have
>> been wondering how PostGIS / PostgreSQL actually distribute parallel
>> work for GIS type data? Is there any form of load balancing to different
>> cores?
>> GIS type data fundamentally differs from "traditional" data with simple
>> text or numeric fields in one crucial aspect: the size distribution of
>> geometries is vastly greater than any difference in size of other basic
>> field types in a database.
>> E.g. polygon geometries may vary from very simple 3 vertex triangle
>> shapes, to vast country boundary polygons having over 1M vertexes. This
>> has a *huge* impact on processing time per record as well. With
>> geometries over 100k vertices, you quickly end up with processing times
>> - per record! - that may extend in the minutes or even hours and in bad
>> cases a day for a single geometry.
>> This means that simply distributing parallel work by distributing e.g.
>> 100M records over 10M chunks for 10 parallel workers, each worker simply
>> getting the next set of available records to process until all have been
>> assigned to a core / parallel worker, can end up very bad in terms of
>> load balancing.
>> Let's assume for example that the table indeed has multiple records with
>> geometries over 1M vertexes in size, and that all of them happen to be
>> in the first 10M chunk of records, whereas the rest of the records has
>> vastly smaller geometries. This could mean a single parallel worker
>> ending up needing to process the bulk of the data in terms of sheer
>> vertex count, and it might as well be processing for days on it! Whereas
>> the other parallel workers, maybe needing to process only 10% percent of
>> all vertex complexity in the table, finish in a few hours.
>> I actually personally developed a Python multi-threaded generalization
>> option that circumvents such issues: it uses the geometry's vertex count
>> as returned by the PostGIS 'ST_NPoints' function to distribute records
>> evenly across all parallel threads. By sorting the records by vertex
>> count, and than interleaving all records from the highest to the lowest
>> vertex count to all parallel threads, all threads end up processing
>> approximately the same number of vertexes. This leads to pretty nice
>> load balancing, with all threads finishing in approximately the same
>> timespan, and all cores of my server maxed out.
>> I realize PostGIS is dependent on PostgreSQL for parallel query
>> execution, and that something like described above may not be directly
>> feasible in a PostgreSQL / PostGIS default installation. Nonetheless I
>> have wondered how the current mechanism for parallel query with GIS data
>> is implemented, and if there is any load balancing based on geometry
>> complexity?
>> Marco Boeringa
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
