[postgis-users] Help with SQL
Nicolas Ribot
nicolas.ribot at gmail.com
Mon Mar 9 02:35:42 PDT 2020
Something like accumulating ids of obstacles for each polygon, ordered by
height, and taking the first element of the array:
select p.id, (array_agg(o.id order by height_m))[1] as heighest_id
from polyobstacles p join obstacles o on st_contains(p.geom, o.geom);
Nicolas
On Mon, 9 Mar 2020 at 10:21, <paul.malm at lfv.se> wrote:
> Hi,
> I have 2 tables:
> obstacles (point layer) with a column height_m (INTEGER) and a
> polyobstacles (polygon layer)
> the point layer has obstacles all over the map and the polygon layer has
> some polygons containing some of the obstacle points.
> Now I would like to select the highest obstacle in each polygon. If there
> is several points with the same highest height a random obstacle of those
> highest shall be selected.
> Is there someone that can get me on the track for such a query, I’m losing
> myself in subqueries?
> Kind regards,
> Paul
> [image: 2_LFV_engelsk_96]
> * Paul Malm*
> Operations AIM
> Direct +46 (0)8 797 70 23 Mobile: +46 (0)708 601115
> paul.malm at lfv.se
> Mail & Visit: Löjtnantsgatan 25, 115 50 Stockholm, Sweden
> Unit phone: +46 (0)8 797 70 20
> www.lfv.se
> Please consider the enviroment before printing this e-mail message.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200309/a9d3e782/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200309/a9d3e782/attachment.jpg>
