[postgis-users] Help with SQL
paul.malm at lfv.se
paul.malm at lfv.se
Tue Mar 10 03:04:23 PDT 2020
Thanks Felix!
Från: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] För Felix Kunde
Skickat: den 9 mars 2020 10:33
Till: postgis-users at lists.osgeo.org
Kopia: postgis-users at lists.osgeo.org
Ämne: Re: [postgis-users] Help with SQL
Hi Paul,
no need for subqueries here. Do a spatial join between polygon and points and start you query with DISTINCT ON (poly.id) poly.id, o.height etc.
DISTINCT ON (poly.id) will get you one row from the JOIN result per polygon. Which one it picks you can control with the final ORDER BY clause - in your case the height values of points.
The first column in the ORDER BY must be the "group" of your DISTINCT ON and then the height value.
cheers
Felix
Gesendet: Montag, 09. März 2020 um 10:21 Uhr
Von: paul.malm at lfv.se
An: postgis-users at lists.osgeo.org
Betreff: [postgis-users] Help with SQL
I have 2 tables:
obstacles (point layer) with a column height_m (INTEGER) and a
polyobstacles (polygon layer)
the point layer has obstacles all over the map and the polygon layer has some polygons containing some of the obstacle points.
Now I would like to select the highest obstacle in each polygon. If there is several points with the same highest height a random obstacle of those highest shall be selected.
Is there someone that can get me on the track for such a query, I’m losing myself in subqueries?
Kind regards,
Paul
[2_LFV_engelsk_96]
Paul Malm
Operations AIM
Direct +46 (0)8 797 70 23 Mobile: +46 (0)708 601115
paul.malm at lfv.se
Mail & Visit: Löjtnantsgatan 25, 115 50 Stockholm, Sweden
Unit phone: +46 (0)8 797 70 20
www.lfv.se<http://www.lfv.se/>
Please consider the enviroment before printing this e-mail message.
_______________________________________________ postgis-users mailing list postgis-users at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200310/c8a65739/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200310/c8a65739/attachment.jpg>
