[postgis-users] PostGIS functions not working on AWS via Lambda function
Alexander Gataric gataric at usa.net
Tue Mar 17 07:37:59 PDT 2020
I get the same error message as if PostGIS isn't installed. Function not found error.
I'm invoking in lambda via python code like this:
import boto3
import psycopg3
def lambda_handler(event,lambda_context)
# login and connection stuff
cur.execute("select * from schema.udf_name (parm1,parm2)")
The UDF invokes several PostGIS functions such as st_dwithin.
⁣Get BlueMail for Android ​
On Mar 17, 2020, 9:04 AM, at 9:04 AM, Giuseppe Broccolo <g.broccolo.7 at gmail.com> wrote:
>Hi Alexander,
>can you add further details (snippet of code, etc.) about this?
>Never tried doing this, but AFAIK AWS lambda runs on preconfigured RDS
>environments,
>maybe it's just enough to include the CREATE EXTENSION.
>Giuseppe.
>Il giorno mar 17 mar 2020 alle ore 12:55 Alexander Gataric
><gataric at usa.net>
>ha scritto:
>> I'm trying to create a service to invoke Postgres UDFs that utilize
>PostGIS
>> functions via an AWS lambda function. The error I get is as if the
>PostGIS
>> extension is not installed. Has anyone encountered this before?
>> Thanks
>> Alex
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200317/562af35d/attachment.html>
