[postgis-users] PostGIS functions not working on AWS via Lambda function
Giuseppe Broccolo g.broccolo.7 at gmail.com
Tue Mar 17 10:07:12 PDT 2020
Ok, as I told befire lambda functions should rely on RDS instances. Once
you open a connection
to the DB through psycopg, enable the Postgis extension with
cur.execute("CREATE EXTENSION postgis")
then try to run your UDF.
Giuseppe.
Il giorno mar 17 mar 2020 alle ore 14:38 Alexander Gataric <gataric at usa.net>
ha scritto:
> I get the same error message as if PostGIS isn't installed. Function not
> found error.
> I'm invoking in lambda via python code like this:
> import boto3
> import psycopg3
> def lambda_handler(event,lambda_context)
> # login and connection stuff
> cur.execute("select * from schema.udf_name (parm1,parm2)")
> The UDF invokes several PostGIS functions such as st_dwithin.
> Get BlueMail for Android <http://www.bluemail.me/r?b=15824>
> On Mar 17, 2020, at 9:04 AM, Giuseppe Broccolo <g.broccolo.7 at gmail.com>
> wrote:
>> Hi Alexander,
>> can you add further details (snippet of code, etc.) about this?
>> Never tried doing this, but AFAIK AWS lambda runs on preconfigured RDS
>> environments,
>> maybe it's just enough to include the CREATE EXTENSION.
>> Giuseppe.
>> Il giorno mar 17 mar 2020 alle ore 12:55 Alexander Gataric <
>> gataric at usa.net> ha scritto:
>>> I'm trying to create a service to invoke Postgres UDFs that utilize
>>> PostGIS
>>> functions via an AWS lambda function. The error I get is as if the
>>> PostGIS
>>> extension is not installed. Has anyone encountered this before?
>>> Thanks
>>> Alex
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200317/b077b0fd/attachment.html>
