[postgis-users] query a certain row from a table. (Willem Hoffmans)
john polo
jpolo at mail.usf.edu
Mon Mar 23 06:24:32 PDT 2020
Thanks, Willem. I'll try that instead.
best regards,
John
On 3/23/2020 2:12 AM, Willem wrote:
> I'm pretty sure it's the limitations of the Shapefile (or, more
> precisely, the underlying .dbf format) that gives the error.
> Those .dbf files can only contain 2GB of data, see also:
> https://en.wikipedia.org/wiki/Shapefile
> So ask yourself the question: why export to shapefile? Try Geopackage,
> for instance, it's better, without those limitations.
> On Mar 20, 2020, at 11:36 PM, john polo <jpolo at mail.usf.edu
> <mailto:jpolo at mail.usf.edu>> wrote:
> Hi,
> I'm trying to export a table of points to a shapefile. The table has
> over 8,000,000 rows. I'm using PostGIS 3.0 and PostGIS Shapefile
> Import/Export Manager on Windows 10. When I try to run the export, I
> keep getting this error:
> Error: record 3329432 could not be created
> I'm not sure how to handle this. My first impulse is find the offending
> row, but I don't know the SQL for such a query. Is there something I
> need to write in a WHERE clause or a different clause to get a specific row?
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Enlightenment is ego's ultimate disappointment.
-Chogyam Trungpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200323/0b0e420f/attachment.html>
