[postgis-users] Any robust regex for searching out addresses?
Roberto Andrade Fonseca randradefonseca at gmail.com
Sun May 3 13:34:54 PDT 2020
Hi:
Maybe this may help you:
https://info.crunchydata.com/blog/quick-and-dirty-address-matching-with-libpostal
Good luck!
El dom., 3 may. 2020 a las 13:50, Paul Ramsey (<pramsey at cleverelephant.ca>)
escribió:
> Also,
> https://docs.google.com/presentation/d/1Fgc_2dzWAzT--HdMEiWj2fFLJNnpxPXmnYXx9Js3xjE/edit#slide=id.g6404bf8f4e_0_0
> > On May 3, 2020, at 11:49 AM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> > create extension address_standardizer
> https://postgis.net/docs/postgis_installation.html#installing_pagc_address_standardizer
> >> On May 3, 2020, at 11:43 AM, Jo <winfixit at gmail.com> wrote:
> >> It would help if you had a bigger sample of valid addresses.
> >> This may be a good starting point:
> >> (\d+)(\w*)(-)?(\d+)(\w*)(\s)([\w\s]+),\s?([\w\s]+),\s?([\w\s]+)
> https://pythex.org/?regex=(%5Cd%2B)(%5Cw*)(-)%3F(%5Cd%2B)(%5Cw*)(%5Cs)(%5B%5Cw%5Cs%5D%2B)%2C%5Cs%3F(%5B%5Cw%5Cs%5D%2B)%2C%5Cs%3F(%5B%5Cw%5Cs%5D%2B)&test_string=223A-5D%20Great%20Avenue%2C%20A%20City%2C%20Planet%20Earth&ignorecase=0&multiline=0&dotall=0&verbose=0
> >> Jo
> >> On Sun, May 3, 2020 at 2:30 PM Shaozhong SHI <shishaozhong at gmail.com>
> wrote:
> >> Hello,
> >> The text patterns is as follows:
> >> 223A-5D Great Avenue, A City, Planet Earth
> >> A robust regex needs to be constructed and tested.
> >> Any clue?
> >> Regards,
> >> Shao
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200503/ee6cf33d/attachment.html>
