[postgis-users] Small question about GEOMETRY typmod registration in geometry_columns
Jorge Gustavo Rocha
jgr at di.uminho.pt
Sun May 3 15:05:30 PDT 2020
Hi Postgisers,
If I create a new table with a generic GEOMETRY column, it is properly
registered in geometry_columns view as type GEOMETRY.
Example:
CREATE TABLE place (
id uuid NOT NULL DEFAULT uuid_generate_v1mc() PRIMARY KEY,
name varchar(255) not NULL,
geom geometry(GEOMETRY,3763) NOT NULL
select f_table_name, type from geometry_columns gc where f_table_name =
'place';
Perfect, as expected!
f_table_name|type |
place |GEOMETRY|
Problem
I want to restrict this generic GEOMETRY column just to LINESTRING and
POLYGON geometries.
To do so, I use the same typmod geometry(GEOMETRY,3763) and an
additional CONSTRAINT, like:
geom geometry(GEOMETRY,3763) NOT null,
CONSTRAINT line_or_polygon CHECK (geometrytype(geom) = 'LINESTRING' OR
geometrytype(geom) = 'POLYGON')
If I do so, the column is registered as LINESTRING and not GEOMETRY.
'place';
f_table_name|type |
place |LINESTRING|
For me, it would make sense to have it registered as GEOMETRY, not
LINESTRING (or POLYGON). Shouldn't it be based just on the typmod?
Best regards,
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
