[postgis-users] Fwd: Re: Broken installs for PostGIS for Ubuntu 20.04LTS / Focal?
Tom van Tilburg
tom.van.tilburg at gmail.com
Wed May 13 11:45:17 PDT 2020
I just had the time to try a postgis install but reached to a different
result of missing libCGAL.
Here's my setting:
Yesterday upgraded to Focal
- Added apt repo for postgres.
- Installed postgres-12 and postgis
- Tried to do 'CREATE EXTENSION postgis':
ERROR: could not load library "/usr/lib/postgresql/12/lib/postgis-3.so":
libCGAL_Core.so.13: cannot open shared object file: No such file or
directory
I tried to manually install libcgal but this doesn't appear to be available
for focal yet.
See: https://packages.ubuntu.com/search?keywords=cgal
The sfcgal library used by postgis is available though:
% sudo dpkg --list |grep cgal
ii libcgal-dev:amd64 5.0.2-3
amd64 C++ library for computational geometry (development
files)
ii libsfcgal1 1.3.7-4ubuntu3
amd64 Library for ISO 19107:2013 and OGC SFA 1.2 for 3D
operations
Your email has a curious parallel to my installation attempt of qgis though
which ended at:
Setting up qgis-providers (1:3.12.2+32focal) ...
/usr/lib/qgis/crssync: symbol lookup error: /usr/lib/libgdal.so.26:
undefined symbol:
GEOSMakeValid_r
Leaving me with an invalid setup of dpkg (only clears after uninstalling
qgis-providers).
All in all, it seems the packages are in an incomplete state currently.
Tom
On Wed, May 13, 2020 at 3:15 PM Marco Boeringa <marco at boeringa.demon.nl>
wrote:
> Thanks Tom,
> I have seen a similar error related to the "libgdal26" library, but that
> was after other trials to get something running on Ubuntu 20.04 Focal,
> where I successfully installed PostGIS 2.5.4, but then encountered issues
> when my code called the "postgis_full_version()" function and errored out
> with the error message below related to the "libgdal.so.26" library.
> However, as said, this was with PostGIS 2.5.4, not with the PostGIS 3.0.1 I
> actually want to install at this moment and that gave the other error
> related to the "postgis-3.so" library.
> SQL Error [XX000]: ERROR: could not load library
> "/usr/lib/postgresql/11/lib/rtpostgis-2.5.so": /usr/lib/libgdal.so.26:
> undefined symbol: GEOSMakeValid_r
> Where: SQL statement "SELECT public.postgis_gdal_version()"
> PL/pgSQL function postgis_full_version() line 34 at SQL statement
> Marco
> Sorry for the short answer, am on the way currently. Will try to do a
> decent report tonight.
> Error is roughly the same but comes from libgdal26 in my case when doing
> apt install qgis after an upgrade to 20.04.
> best, Tom
> On Wed, 13 May 2020, 14:48 Marco Boeringa, <marco at boeringa.demon.nl>
> wrote:
>> Thanks for the response Tom, but could you be a bit more specific?
>> What do you mean with "Same problem with qgis"? Do you mean you've also
>> encountered a "undefined symbol: GEOSMakeValid" error related to the
>> "postgis-3.so" library when trying to use some tool in QGIS?
>> I have installed PostgreSQL 12 and PostGIS 3.0.1 via Synaptic on Ubuntu
>> 20.04 (Focal) and use CREATE EXTENSION (via pgAdmin4), when I encounter the
>> error.
>> Marco
>> Op 13-5-2020 om 14:40 schreef Tom van Tilburg:
>> On Wed, 13 May 2020, 11:14 Marco Boeringa, <marco at boeringa.demon.nl>
>> wrote:
>>> Hi all,
>>> Is there someone who can confirm they have been able to install PostGIS
>>> 3.0.1 via the official APT repository?:
>>> https://wiki.postgresql.org/wiki/Apt
>>> After using the Synaptics Package Manager to install the three packages
>>> involved
>>> ("postgresql-12-postgis-3"/"postgresql-12-postgis-3-dbgsym"/"postgresql-12-postgis-3-scripts"),
>>> and subsequently trying to create the PostGIS extension in pgAdmin4, I
>>> get the following error:
>>> /usr/lib/postgresql/12/lib/postgis-3.so: undefined symbol: GEOSMakeValid
>>> I have been trying different things to fix this for past two days
>>> including re-install, but to no avail. I have also attempted to include
>>> the UbuntuGIS repository as a potential alternative resource of PostGIS
>>> packages, but discovered the UbuntuGIS repository is lagging behind and
>>> doesn't yet have packages for 20.04LTS.
>>> Marco
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200513/b86f40a8/attachment.html>
