[postgis-users] Fwd: Re: Broken installs for PostGIS for Ubuntu 20.04LTS / Focal?
Tom van Tilburg
tom.van.tilburg at gmail.com
Thu May 14 01:32:32 PDT 2020
I think I solved it.
The issue lies with gdal, not postgis (test by running `gdalinfo`), and it
turns out there was an old install of libgeos (3.7) in my /us/local/lib.
After simply removing all related files in /usr/local/lib gdal (and postgis
and qgis) stopped complaining (I had to remove old installs of geos, proj
and sfcgal for that).
This issue put me on the right track:
https://github.com/OSGeo/gdal/issues/2214
T.
On Wed, May 13, 2020 at 3:15 PM Marco Boeringa <marco at boeringa.demon.nl>
wrote:
> Thanks Tom,
> I have seen a similar error related to the "libgdal26" library, but that
> was after other trials to get something running on Ubuntu 20.04 Focal,
> where I successfully installed PostGIS 2.5.4, but then encountered issues
> when my code called the "postgis_full_version()" function and errored out
> with the error message below related to the "libgdal.so.26" library.
> However, as said, this was with PostGIS 2.5.4, not with the PostGIS 3.0.1 I
> actually want to install at this moment and that gave the other error
> related to the "postgis-3.so" library.
> SQL Error [XX000]: ERROR: could not load library
> "/usr/lib/postgresql/11/lib/rtpostgis-2.5.so": /usr/lib/libgdal.so.26:
> undefined symbol: GEOSMakeValid_r
> Where: SQL statement "SELECT public.postgis_gdal_version()"
> PL/pgSQL function postgis_full_version() line 34 at SQL statement
> Marco
> Sorry for the short answer, am on the way currently. Will try to do a
> decent report tonight.
> Error is roughly the same but comes from libgdal26 in my case when doing
> apt install qgis after an upgrade to 20.04.
> best, Tom
> On Wed, 13 May 2020, 14:48 Marco Boeringa, <marco at boeringa.demon.nl>
> wrote:
>> Thanks for the response Tom, but could you be a bit more specific?
>> What do you mean with "Same problem with qgis"? Do you mean you've also
>> encountered a "undefined symbol: GEOSMakeValid" error related to the
>> "postgis-3.so" library when trying to use some tool in QGIS?
>> I have installed PostgreSQL 12 and PostGIS 3.0.1 via Synaptic on Ubuntu
>> 20.04 (Focal) and use CREATE EXTENSION (via pgAdmin4), when I encounter the
>> error.
>> Marco
>> Op 13-5-2020 om 14:40 schreef Tom van Tilburg:
>> On Wed, 13 May 2020, 11:14 Marco Boeringa, <marco at boeringa.demon.nl>
>> wrote:
>>> Hi all,
>>> Is there someone who can confirm they have been able to install PostGIS
>>> 3.0.1 via the official APT repository?:
>>> https://wiki.postgresql.org/wiki/Apt
>>> After using the Synaptics Package Manager to install the three packages
>>> involved
>>> ("postgresql-12-postgis-3"/"postgresql-12-postgis-3-dbgsym"/"postgresql-12-postgis-3-scripts"),
>>> and subsequently trying to create the PostGIS extension in pgAdmin4, I
>>> get the following error:
>>> ERROR: could not load library "/usr/lib/postgresql/12/lib/postgis-3.so":
>>> /usr/lib/postgresql/12/lib/postgis-3.so: undefined symbol: GEOSMakeValid
>>> I have been trying different things to fix this for past two days
>>> including re-install, but to no avail. I have also attempted to include
>>> the UbuntuGIS repository as a potential alternative resource of PostGIS
>>> packages, but discovered the UbuntuGIS repository is lagging behind and
>>> doesn't yet have packages for 20.04LTS.
>>> Marco
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200514/26e3ecbc/attachment.html>
