[postgis-users] Fwd: Re: Broken installs for PostGIS for Ubuntu 20.04LTS / Focal?
Marco Boeringa
marco at boeringa.demon.nl
Thu May 14 07:13:52 PDT 2020
Tom,
Thanks for this info.
I now discovered that, despite removing the "libgeos-3.7.0" by using
Synaptic, I also had a secondary version living in my "/usr/local/lib/"
folder. Purging all "libgeos" prefixed files with the command you
supplied, indeed made it now possible to use CREATE EXTENSION for
PostGIS in pgAdmin4. So there was a conflict lurking there in the
"/usr/local/lib/" folder. I actually have no idea how the libgeos files
ended up there, or why they weren't removed by Synaptic if that used to
be the official installation folder.
I don't know if this is the only issue though, and would need to start
to test the current installation properly in order to make sure
everything is truly OK now, but it is at least a significant step forward.
Marco
Op 14-5-2020 om 11:42 schreef Tom van Tilburg:
> Whatever lives in /usr/local/lib was my manual build so I had to
> delete that manually.
> I did `sudo rm /usr/local/lib/libgeos*` (same for proj and sfcgal)
> On top of that I purged all old package configurations `sudo apt purge
> <packagename>` just to be sure but I don't think it is needed.
> Best,
> Tom
> On Thu, May 14, 2020 at 10:45 AM Marco Boeringa
> <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl>> wrote:
> Hi Tom,
> Thanks for the tip, but what did you do to remove the old install?
> Did you rely on Apt or Synaptic to remove the old libgeos version,
> or did you manually clean up folders? I had two versions of
> libgeos as well (3.7 and 3.8) if I remember well (need to start up
> the VM again to check), and removed the older one through Synaptic
> just leaving the 3.8 version, but that wasn't enough to solve my
> particular issues.
> Marco
> Op 14-5-2020 om 10:32 schreef Tom van Tilburg:
>> I think I solved it.
>> The issue lies with gdal, not postgis (test by running
>> `gdalinfo`), and it turns out there was an old install of libgeos
>> (3.7) in my /us/local/lib. After simply removing all related
>> files in /usr/local/lib gdal (and postgis and qgis) stopped
>> complaining (I had to remove old installs of geos, proj and
>> sfcgal for that).
>> This issue put me on the right track:
>> https://github.com/OSGeo/gdal/issues/2214
>> T.
>> On Wed, May 13, 2020 at 3:15 PM Marco Boeringa
>> Thanks Tom,
>> I have seen a similar error related to the "libgdal26"
>> library, but that was after other trials to get something
>> running on Ubuntu 20.04 Focal, where I successfully installed
>> PostGIS 2.5.4, but then encountered issues when my code
>> called the "postgis_full_version()" function and errored out
>> with the error message below related to the "libgdal.so.26"
>> library. However, as said, this was with PostGIS 2.5.4, not
>> with the PostGIS 3.0.1 I actually want to install at this
>> moment and that gave the other error related to the
>> "postgis-3.so" library.
>> SQL Error [XX000]: ERROR: could not load library
>> "/usr/lib/postgresql/11/lib/rtpostgis-2.5.so
>> <http://rtpostgis-2.5.so>": /usr/lib/libgdal.so.26: undefined
>> symbol: GEOSMakeValid_r
>> Where: SQL statement "SELECT public.postgis_gdal_version()"
>> PL/pgSQL function postgis_full_version() line 34 at SQL statement
>> Marco
>> Sorry for the short answer, am on the way currently. Will try
>> to do a decent report tonight.
>> Error is roughly the same but comes from libgdal26 in my case
>> when doing apt install qgis after an upgrade to 20.04.
>> best, Tom
>> On Wed, 13 May 2020, 14:48 Marco Boeringa,
>> Thanks for the response Tom, but could you be a bit more
>> specific?
>> What do you mean with "Same problem with qgis"? Do you
>> mean you've also encountered a "undefined symbol:
>> GEOSMakeValid" error related to the "postgis-3.so"
>> library when trying to use some tool in QGIS?
>> I have installed PostgreSQL 12 and PostGIS 3.0.1 via
>> Synaptic on Ubuntu 20.04 (Focal) and use CREATE EXTENSION
>> (via pgAdmin4), when I encounter the error.
>> Marco
>> Op 13-5-2020 om 14:40 schreef Tom van Tilburg:
>>> On Wed, 13 May 2020, 11:14 Marco Boeringa,
>>> Hi all,
>>> Is there someone who can confirm they have been able
>>> to install PostGIS
>>> 3.0.1 via the official APT repository?:
>>> https://wiki.postgresql.org/wiki/Apt
>>> After using the Synaptics Package Manager to install
>>> the three packages
>>> involved
>>> ("postgresql-12-postgis-3"/"postgresql-12-postgis-3-dbgsym"/"postgresql-12-postgis-3-scripts"),
>>> and subsequently trying to create the PostGIS
>>> extension in pgAdmin4, I
>>> get the following error:
>>> "/usr/lib/postgresql/12/lib/postgis-3.so":
>>> /usr/lib/postgresql/12/lib/postgis-3.so: undefined
>>> I have been trying different things to fix this for
>>> past two days
>>> including re-install, but to no avail. I have also
>>> attempted to include
>>> the UbuntuGIS repository as a potential alternative
>>> resource of PostGIS
>>> packages, but discovered the UbuntuGIS repository is
>>> lagging behind and
>>> doesn't yet have packages for 20.04LTS.
>>> Marco
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> <mailto:postgis-users at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200514/07249782/attachment.html>
