[postgis-users] Fwd: Re: Broken installs for PostGIS for Ubuntu 20.04LTS / Focal?
Marco Boeringa marco at boeringa.demon.nl
Fri May 15 01:38:09 PDT 2020
Tom,
One more question:
After successfully installing the PostGIS 3.0.1 extension using CREATE
EXTENSION in pgAdmin4 on PostgreSQL 12.3 on Ubuntu 20.04 Focal, I now
ran into an issue where it appears the 'ST_Accum' function is missing in
my PostGIS install. My code calls this, and it failed. I then had a look
at the function list in pgAdmin, and indeed 'ST_Accum' is not listed. I
do see loads of other PostGIS functions, just 'ST_Accum' seems missing
(although I cannot garantuee there are a few more missing functions, but
the list seems pretty comprehensive from a quick look, and the CREATE
EXTENSION call went without a hitch).
Can you confirm you see 'ST_Accum' in your PostGIS 3.0.1 function list
if you look in pgAdmin? The PostGIS Help does not mention some
deprecation of this function:
https://postgis.net/docs/ST_Accum.html
Marco
Op 14-5-2020 om 11:42 schreef Tom van Tilburg:
> Whatever lives in /usr/local/lib was my manual build so I had to
> delete that manually.
> I did  `sudo rm /usr/local/lib/libgeos*` (same for proj and sfcgal)
> On top of that I purged all old package configurations `sudo apt purge
> <packagename>` just to be sure but I don't think it is needed.
> Best,
>  Tom
> On Thu, May 14, 2020 at 10:45 AM Marco Boeringa
> <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl>> wrote:
>     Hi Tom,
>     Thanks for the tip, but what did you do to remove the old install?
>     Did you rely on Apt or Synaptic to remove the old libgeos version,
>     or did you manually clean up folders? I had two versions of
>     libgeos as well (3.7 and 3.8) if I remember well (need to start up
>     the VM again to check), and removed the older one through Synaptic
>     just leaving the 3.8 version, but that wasn't enough to solve my
>     particular issues.
>     Marco
>     Op 14-5-2020 om 10:32 schreef Tom van Tilburg:
>>     I think I solved it.
>>     The issue lies with gdal, not postgis (test by running
>>     `gdalinfo`), and it turns out there was an old install of libgeos
>>     (3.7) in my /us/local/lib. After simply removing all related
>>     files in /usr/local/lib gdal (and postgis and qgis) stopped
>>     complaining (I had to remove old installs of geos, proj and
>>     sfcgal for that).
>>     This issue put me on the right track:
>>     https://github.com/OSGeo/gdal/issues/2214
>>     T.
>>     On Wed, May 13, 2020 at 3:15 PM Marco Boeringa
>>         Thanks Tom,
>>         I have seen a similar error related to the "libgdal26"
>>         library, but that was after other trials to get something
>>         running on Ubuntu 20.04 Focal, where I successfully installed
>>         PostGIS 2.5.4, but then encountered issues when my code
>>         called the "postgis_full_version()" function and errored out
>>         with the error message below related to the "libgdal.so.26"
>>         library. However, as said, this was with PostGIS 2.5.4, not
>>         with the PostGIS 3.0.1 I actually want to install at this
>>         moment and that gave the other error related to the
>>         "postgis-3.so" library.
>>         SQL Error [XX000]: ERROR: could not load library
>>         "/usr/lib/postgresql/11/lib/rtpostgis-2.5.so
>>         <http://rtpostgis-2.5.so>": /usr/lib/libgdal.so.26: undefined
>>         symbol: GEOSMakeValid_r
>>           Where: SQL statement "SELECT public.postgis_gdal_version()"
>>         PL/pgSQL function postgis_full_version() line 34 at SQL statement
>>         Marco
>>         Sorry for the short answer, am on the way currently. Will try
>>         to do a decent report tonight.
>>         Error is roughly the same but comes from libgdal26 in my case
>>         when doing apt install qgis after an upgrade to 20.04.
>>         best, Tom
>>         On Wed, 13 May 2020, 14:48 Marco Boeringa,
>>             Thanks for the response Tom, but could you be a bit more
>>             specific?
>>             What do you mean with "Same problem with qgis"? Do you
>>             mean you've also encountered a "undefined symbol:
>>             GEOSMakeValid" error related to the "postgis-3.so"
>>             library when trying to use some tool in QGIS?
>>             I have installed PostgreSQL 12 and PostGIS 3.0.1 via
>>             Synaptic on Ubuntu 20.04 (Focal) and use CREATE EXTENSION
>>             (via pgAdmin4), when I encounter the error.
>>             Marco
>>             Op 13-5-2020 om 14:40 schreef Tom van Tilburg:
>>>             On Wed, 13 May 2020, 11:14 Marco Boeringa,
>>>                 Hi all,
>>>                 Is there someone who can confirm they have been able
>>>                 to install PostGIS
>>>                 3.0.1 via the official APT repository?:
>>>                 https://wiki.postgresql.org/wiki/Apt
>>>                 After using the Synaptics Package Manager to install
>>>                 the three packages
>>>                 involved
>>>                 ("postgresql-12-postgis-3"/"postgresql-12-postgis-3-dbgsym"/"postgresql-12-postgis-3-scripts"),
>>>                 and subsequently trying to create the PostGIS
>>>                 extension in pgAdmin4, I
>>>                 get the following error:
>>>                 "/usr/lib/postgresql/12/lib/postgis-3.so":
>>>                 /usr/lib/postgresql/12/lib/postgis-3.so: undefined
>>>                 I have been trying different things to fix this for
>>>                 past two days
>>>                 including re-install, but to no avail. I have also
>>>                 attempted to include
>>>                 the UbuntuGIS repository as a potential alternative
>>>                 resource of PostGIS
>>>                 packages, but discovered the UbuntuGIS repository is
>>>                 lagging behind and
>>>                 doesn't yet have packages for 20.04LTS.
>>>                 Marco
>>>                 _______________________________________________
>>>                 postgis-users mailing list
>>>                 postgis-users at lists.osgeo.org
>>>                 <mailto:postgis-users at lists.osgeo.org>
>>>                 https://lists.osgeo.org/mailman/listinfo/postgis-users
>>>             postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200515/dd1e20b6/attachment.html>
