[postgis-users] Fwd: Re: Broken installs for PostGIS for Ubuntu 20.04LTS / Focal?
Tom van Tilburg tom.van.tilburg at gmail.com
Fri May 15 02:52:20 PDT 2020
It's the first thing I ran into as well after upgrading .
But it hasn't been mentioned in the docs? Whoops... time for an issue...
Tom
On Fri, May 15, 2020 at 10:56 AM Marco Boeringa <marco at boeringa.demon.nl>
wrote:
> Tom,
> It now appears the PostGIS team indeed removed 'ST_Accum', but forgot to
> update the online PostGIS Help. I see two OSGEO tickets related to this:
> https://trac.osgeo.org/postgis/ticket/4356
> https://trac.osgeo.org/postgis/changeset/17397
> Both mention replacing 'ST_Accum' with 'array_agg'.
> Marco
> Op 15-5-2020 om 10:38 schreef Marco Boeringa:
> Tom,
> One more question:
> After successfully installing the PostGIS 3.0.1 extension using CREATE
> EXTENSION in pgAdmin4 on PostgreSQL 12.3 on Ubuntu 20.04 Focal, I now ran
> into an issue where it appears the 'ST_Accum' function is missing in my
> PostGIS install. My code calls this, and it failed. I then had a look at
> the function list in pgAdmin, and indeed 'ST_Accum' is not listed. I do see
> loads of other PostGIS functions, just 'ST_Accum' seems missing (although I
> cannot garantuee there are a few more missing functions, but the list seems
> pretty comprehensive from a quick look, and the CREATE EXTENSION call went
> without a hitch).
> Can you confirm you see 'ST_Accum' in your PostGIS 3.0.1 function list if
> you look in pgAdmin? The PostGIS Help does not mention some deprecation of
> this function:
> https://postgis.net/docs/ST_Accum.html
> Marco
> Op 14-5-2020 om 11:42 schreef Tom van Tilburg:
> Whatever lives in /usr/local/lib was my manual build so I had to delete
> that manually.
> I did  `sudo rm /usr/local/lib/libgeos*` (same for proj and sfcgal)
> On top of that I purged all old package configurations `sudo apt purge
> <packagename>` just to be sure but I don't think it is needed.
> Best,
>  Tom
> On Thu, May 14, 2020 at 10:45 AM Marco Boeringa <marco at boeringa.demon.nl>
> wrote:
>> Hi Tom,
>> Thanks for the tip, but what did you do to remove the old install? Did
>> you rely on Apt or Synaptic to remove the old libgeos version, or did you
>> manually clean up folders? I had two versions of libgeos as well (3.7 and
>> 3.8) if I remember well (need to start up the VM again to check), and
>> removed the older one through Synaptic just leaving the 3.8 version, but
>> that wasn't enough to solve my particular issues.
>> Marco
>> Op 14-5-2020 om 10:32 schreef Tom van Tilburg:
>> I think I solved it.
>> The issue lies with gdal, not postgis (test by running `gdalinfo`), and
>> it turns out there was an old install of libgeos (3.7) in my /us/local/lib.
>> After simply removing all related files in /usr/local/lib gdal (and postgis
>> and qgis) stopped complaining (I had to remove old installs of geos, proj
>> and sfcgal for that).
>> This issue put me on the right track:
>> https://github.com/OSGeo/gdal/issues/2214
>> T.
>> On Wed, May 13, 2020 at 3:15 PM Marco Boeringa <marco at boeringa.demon.nl>
>> wrote:
>>> Thanks Tom,
>>> I have seen a similar error related to the "libgdal26" library, but that
>>> was after other trials to get something running on Ubuntu 20.04 Focal,
>>> where I successfully installed PostGIS 2.5.4, but then encountered issues
>>> when my code called the "postgis_full_version()" function and errored out
>>> with the error message below related to the "libgdal.so.26" library.
>>> However, as said, this was with PostGIS 2.5.4, not with the PostGIS 3.0.1 I
>>> actually want to install at this moment and that gave the other error
>>> related to the "postgis-3.so" library.
>>> SQL Error [XX000]: ERROR: could not load library
>>> "/usr/lib/postgresql/11/lib/rtpostgis-2.5.so": /usr/lib/libgdal.so.26:
>>> undefined symbol: GEOSMakeValid_r
>>>   Where: SQL statement "SELECT public.postgis_gdal_version()"
>>> PL/pgSQL function postgis_full_version() line 34 at SQL statement
>>> Marco
>>> Sorry for the short answer, am on the way currently. Will try to do a
>>> decent report tonight.
>>> Error is roughly the same but comes from libgdal26 in my case when doing
>>> apt install qgis after an upgrade to 20.04.
>>> best, Tom
>>> On Wed, 13 May 2020, 14:48 Marco Boeringa, <marco at boeringa.demon.nl>
>>> wrote:
>>>> Thanks for the response Tom, but could you be a bit more specific?
>>>> What do you mean with "Same problem with qgis"? Do you mean you've also
>>>> encountered a "undefined symbol: GEOSMakeValid" error related to the
>>>> "postgis-3.so" library when trying to use some tool in QGIS?
>>>> I have installed PostgreSQL 12 and PostGIS 3.0.1 via Synaptic on Ubuntu
>>>> 20.04 (Focal) and use CREATE EXTENSION (via pgAdmin4), when I encounter the
>>>> error.
>>>> Marco
>>>> Op 13-5-2020 om 14:40 schreef Tom van Tilburg:
>>>> On Wed, 13 May 2020, 11:14 Marco Boeringa, <marco at boeringa.demon.nl>
>>>> wrote:
>>>>> Hi all,
>>>>> Is there someone who can confirm they have been able to install
>>>>> PostGIS
>>>>> 3.0.1 via the official APT repository?:
>>>>> https://wiki.postgresql.org/wiki/Apt
>>>>> After using the Synaptics Package Manager to install the three
>>>>> packages
>>>>> involved
>>>>> ("postgresql-12-postgis-3"/"postgresql-12-postgis-3-dbgsym"/"postgresql-12-postgis-3-scripts"),
>>>>> and subsequently trying to create the PostGIS extension in pgAdmin4, I
>>>>> get the following error:
>>>>> "/usr/lib/postgresql/12/lib/postgis-3.so":
>>>>> /usr/lib/postgresql/12/lib/postgis-3.so: undefined symbol:
>>>>> GEOSMakeValid
>>>>> I have been trying different things to fix this for past two days
>>>>> including re-install, but to no avail. I have also attempted to
>>>>> include
>>>>> the UbuntuGIS repository as a potential alternative resource of
>>>>> PostGIS
>>>>> packages, but discovered the UbuntuGIS repository is lagging behind
>>>>> and
>>>>> doesn't yet have packages for 20.04LTS.
>>>>> Marco
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>>>> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200515/8f8cf434/attachment.html>
