[postgis-users] Spatial linking or selection
Shaozhong SHI
shishaozhong at gmail.com
Fri May 15 03:50:17 PDT 2020
Hi, Nicolas,
Thanks.
That is very interesting. I will test it.
I could not find information on how distance is defined. 0.01 stands on
what unit?
https://postgis.net/docs/ST_DWithin.html
Regards,
Shao
On Fri, 15 May 2020 at 11:32, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:
> Hi,
> You can test for proximity between start and end points
> Create spatial indexes on st_startpoint(geom) and st_endpoint(geom) on
> your line features table (also index starting and ending points column in
> table one)
> select t.id, r.id, r.geom
> from start_end_table t join roads r on st_dwithin(t.startpoint,
> st_startpoint(r.geom), 0.01) and st_dwithin(t.endpoint,
> st_endpoint(r.geom), 0.01)
> Adjust the 0.01 distance according to your data and their precision.
> Nicolas
> On Fri, 15 May 2020 at 11:42, Shaozhong SHI <shishaozhong at gmail.com>
> wrote:
>> Given 2 tables. One has the starting and ending points of roads, and the
>> other has line features. How best to do spatial linking or selection of
>> road features?
>> Can anyone enlighten me?
>> Regards,
>> Shao
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200515/c84a457a/attachment.html>
