[postgis-users] Spatial linking or selection
Nicolas Ribot nicolas.ribot at gmail.com
Fri May 15 04:10:33 PDT 2020
On Fri, 15 May 2020 at 12:56, Shaozhong SHI <shishaozhong at gmail.com> wrote:
> Hi, Nicolas,
> Thanks.
> That is very interesting.  I will test it.
> I could not find information on how distance is defined.  0.01 stands on
> what unit?
In the unit of your spatial reference system (see its wkt or proj4
definition in spatial_ref_sys table to figure out the SRS unit)
https://postgis.net/docs/ST_DWithin.html
> Regards,
> Shao
> On Fri, 15 May 2020 at 11:32, Nicolas Ribot <nicolas.ribot at gmail.com>
> wrote:
>> Hi,
>> You can test for proximity between start and end points
>> Create spatial indexes on st_startpoint(geom) and st_endpoint(geom) on
>> your line features table (also index starting and ending points column in
>> table one)
>> select t.id, r.id, r.geom
>> from start_end_table t join roads r on st_dwithin(t.startpoint,
>> st_startpoint(r.geom), 0.01) and st_dwithin(t.endpoint,
>> st_endpoint(r.geom), 0.01)
>> Adjust the 0.01 distance according to your data and their precision.
>> Nicolas
>> On Fri, 15 May 2020 at 11:42, Shaozhong SHI <shishaozhong at gmail.com>
>> wrote:
>>> Given 2 tables.  One has the starting and ending points of roads, and
>>> the other has line features.  How best to do spatial linking or selection
>>> of road features?
>>> Can anyone enlighten me?
>>> Regards,
>>> Shao
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200515/06aa0288/attachment.html>
