[postgis-users] Spatial linking or selection
Shaozhong SHI
shishaozhong at gmail.com
Fri May 15 05:35:25 PDT 2020
Hi, Friends,
I am a little bit confused.
If I use geometry as data type, do I put something like 5 metres and
use_spheroid=false?
Is that correct?
Regards,
Shao
On Fri, 15 May 2020 at 13:00, Giuseppe Broccolo <g.broccolo.7 at gmail.com>
wrote:
> Hi Shao,
> Il giorno ven 15 mag 2020 alle ore 11:56 Shaozhong SHI <
> shishaozhong at gmail.com> ha scritto:
>> Hi, Nicolas,
>> Thanks.
>> That is very interesting. I will test it.
>> I could not find information on how distance is defined. 0.01 stands on
>> what unit?
>> https://postgis.net/docs/ST_DWithin.html
> Have a look to this statement in the doc you linked:
> For geometry: The distance is specified in units defined by the spatial
> reference system of the geometries. For this function to make sense, the
> source geometries must both be of the same coordinate projection, having
> the same SRID.
> For geography units are in meters and measurement is defaulted to
> use_spheroid=true, for faster check, use_spheroid=false to measure along
> sphere.
> Giuseppe.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200515/e8ee90e1/attachment.html>
