[postgis-users] Suggestion to improve query performance for GIS query.
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Fri May 22 07:24:27 PDT 2020
This query will most likely do a full table because the where cause
uses  like '%...'. Because the leading % is a wildcard, it has to do a
full table scan and can not use an index.
-Steve W
On 5/22/2020 2:59 AM, postgann2020 s wrote:
> Hi Team,
> Thanks for your support.
> Could you please suggest on below query.
> EnvironmentPostgreSQL: 9.5.15
> Postgis: 2.2.7
> The table contains GIS data which is fiber data(underground routes).
> We are using the below query inside the proc which is taking a long
> time to complete.
> SELECT seq_no+1 INTO pair_seq_no FROM SCHEMA.TABLE WHERE (Column1 like
> '%,sheath--'||cable_seq_id ||',%' or Column1 like
> 'sheath--'||cable_seq_id ||',%' or Column1 like
> '%,sheath--'||cable_seq_id  or Column1='sheath--'||cable_seq_id) order
> by seq_no desc limit 1 ;
> We have created an index on parental_path Column1 still it is taking
> 4secs to get the results.
> Could you please suggest a better way to execute the query.
> Regards,
> PostgAnn.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
