[postgis-users] Suggestion to improve query performance for GIS	query.
    postgann2020 s
    postgann2020 at gmail.com
    Fri May 22 00:34:21 PDT 2020
Thanks for your support David and Afsar.
Hi David,
Could you please suggest the resource link to  "Add a trigger to the table
to normalize the contents of column1 upon insert and then rewrite your
query to reference the newly created normalized fields." if anything
available. So that it will help me to get into issues.
Thanks for your support.
Regards,
Postgann.
On Fri, May 22, 2020 at 12:46 PM Mohammed Afsar <vmdapsar at gmail.com> wrote:
> Dear team,
> Kindly try to execute the vacuum analyzer on that particular table and
> refresh the session and execute the query.
> VACUUM (VERBOSE, ANALYZE) tablename;
> Regards,
> Mohammed Afsar
> Database engineer
> On Fri, May 22, 2020, 12:30 PM postgann2020 s <postgann2020 at gmail.com>
> wrote:
>> Hi Team,
>> Could you please suggest on below query.
>> EnvironmentPostgreSQL: 9.5.15
>> Postgis: 2.2.7
>> The table contains GIS data which is fiber data(underground routes).
>> We are using the below query inside the proc which is taking a long time
>> to complete.
>> SELECT seq_no+1 INTO pair_seq_no FROM SCHEMA.TABLE WHERE (Column1 like
>> '%,sheath--'||cable_seq_id ||',%' or Column1 like 'sheath--'||cable_seq_id
>> ||',%' or Column1 like '%,sheath--'||cable_seq_id  or
>> Column1='sheath--'||cable_seq_id) order by seq_no desc limit 1 ;
>> We have created an index on parental_path Column1 still it is taking
>> 4secs to get the results.
>> Could you please suggest a better way to execute the query.
>> Regards,
>> PostgAnn.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200522/f657ec10/attachment.html>
