[postgis-users] Postgis Update from 2.4 to 3.0
William Kyngesburye
woklist at kyngchaos.com
Tue May 26 05:45:55 PDT 2020
There is one key step that tripped me up - the raster part of PostGIS was split into its own extension. After updating the extensions within Postgres, the new postgis-raster extension will be "updated" as an "unpackaged" extension - it won't be visible but will be there and usable. It could cause trouble later if you upgrade Postgis again or Postgres (I had a couple missing raster functions that caused a Postgres upgrade failure).
To fix this see the manual, there's a note at the bottom of the soft upgrade with extensions section.
William Kyngesburye
<kyngchaos at kyngchaos.com>
<http://www.kyngchaos.com>
Don't Panic
> On May 26, 2020, at 3:30 AM, Zwettler Markus (OIZ) <Markus.Zwettler at zuerich.ch> wrote:
> Hi,
> We used and had postgis24 installed:
> postgis24_96-client-2.4.8-5.rhel7.x86_64
> postgis24_96-2.4.8-5.rhel7.x86_64
> pgrouting_96-2.6.2-1.rhel7.x86_64
> ogr_fdw96-1.0.8-1.rhel7.x86_64
> After an Linux update postgis30 packages were installed:
> postgis30_96-client-3.0.1-5.rhel7.x86_64
> postgis30_96-3.0.1-5.rhel7.x86_64
> pgrouting_96-3.0.0-rc1_2.rhel7.x86_64
> ogr_fdw96-1.0.9-1.rhel7.x86_64
> Afaik, we must do an "alter extension postgis update" now.
> QUESTION: Is an update to postgis30 that easy? Could there be any problems?
> Thanks,
> Markus
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200526/e00300bc/attachment.html>
